Question about Akai Audio Players & Recorders
AKAI STEREO RECORDER 1722 reel to reel
Reel to Reel AKAI STEREO RECORDER 1722 does it take 10 inch reels
    New Friend:
So what was the answer? can the akai 1772 take 10 inch reels as well as 7 inch? please
Posted on Mar 14, 2014
4 Suggested Answers
SOURCE: How do I thread the tape on an Akai GX210D reel to
When facing the deck, the feed reel goes on the left and the take-up reel goes on the right. Make sure to secure each reel by engaging the reel locks on each of the spindles. Place the feed reel with the free end of the tape on the left and hanging downwards (like the letter "P"). Pass the tape to the right of the tension spindle (which is above and to the left of the play/record heads unit. Pull the tape down and pass it underneath the heads from left to right. Then on the right hand side of the heads unit pass the tape between the guide wheel and the first guide spindle to its left and just above. Then pass the tape over the top of the second guide spindle. Finally, loop the tape under the right hand tension spindle and pull it up and feed onto the take-up reel from the right in an anticlockwise direction (like the letter "g"). Once you have it through the slot in the centre of the reel, hold the tape end there with your finger and wind the reel around a few times to hold the tape in place and ... Voila!
Posted on Mar 29, 2009
  • 3 Answers
SOURCE: RCA REEL MEDIA CENTER- NEED REELS
The RCA Reel Media Center was made by Polyconcept USA, however their website has been down since 2008, so they may have gone bankrupt, or gone out of business.
As for the reels, you can use Nagra 1/8" reels wich has the same tape width, but the hub is different, so you will need to make your own hub adaptor.
I found a seller on Ebay selling blank 1/8" Nagra tapes: Link
Posted on Jul 20, 2009
Grubhead
  • 5455 Answers
SOURCE: I OWN A AKAI 4000DS MK2 REEL TO REEL TAPE
All you need is to connect the Tape deck via a lead to the audio input of your computer. You can then get a audio recording software (I use and recomend Dan Das Digital Audio Editor). It will record the audio and then you can save it to any number of audio formats. There are some basic processing functions on most Audio Editors, but for more advance features get Audio Cleaning Lab, by Magix. You can record direct with this software. But it's easier to import files into it, due to the fact that they have made the cutting functions complex to use, but the special features easy!
Posted on Dec 22, 2009
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Manual for AKAI MK8 reel to reel recorder
Do an online search for Akai MK8 data. I was able to get information for my Akai that way
Jun 17, 2013 | Audio Players & Recorders
I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Oct 24, 2009 | Audio Players & Recorders
What are the best tapes to buy to recrod from your reel to reel. I have some tapes that record and some don;t. Is it becaue they old or defected. Help me out. vp
maxell or tdk (which is hard to find now)....if your reel is 7 inch you want 1800 ft, normal bias (lo noise hi output) tape (for 10 inch you will use the 2400 ft) ....anything longer your tape will be dragging (both while recording and playing) hope this is helpful...feel free to rate
Feb 22, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
I need to replace a part for my reel-to-reel tape recorder: The machine is Akai Model No. 1722 II, and a friend of mine, a sound man, describes the part that needs replacing like this: A Dual Condenser...
1 Microfarad is easy, you need to specify a voltage rating though. These are easily available from any elextronics parts supplier. There are many on the web. Post the voltage and I'll list a few.
Dan
May 20, 2008 | Audio Players & Recorders
199 people viewed this question
Top Akai Audio Players & Recorders Experts
Michael Harrier
Vernon Taylor
 Grubhead
Grubhead
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
