Question about Dishwashers
Size specs i need size specs of a kitchen aid dishwasher model #kds-16
The measurements are difficult to find and verify. However, you can call Kitchen Aid. They will be able to mail or fax you a copy of the original user manual which should have the specs. The number is: 800-422-1230
Posted on Jan 08, 2009
Does anyone have the specs for this model, HxWxD
Watts (W) 1300 W
Current (A) 12 A
Volts (V) 120 V
Frequency (Hz) 60 Hz
Tub type TallTub
Plug type 120V-3 prong
Dimensions & Weight
Overall appliance dimensions (HxWxD) (in) 34 1/8 '' x 23 9/16 '' x 22 7/16 ''
Required cutout size (HxWxD) (in) 34 1/8 '' x 24 '' x 24 ''
Product packaging dimensions (HxWxD) (in) 36 13/16'' x 26'' x 28''
Length inlet hose (in) 55''
Gross weight (lbs) 123 lbs
Net weight (lbs) 118 lbs
Of course you don't mention which model you have ??
Mar 18, 2016 | Bosch SHX68P05UC Dishwasher
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
SPECS FOR A KITCHENAID DISHWASHER MODEL # KUDL03FVSS
Here are some specs, hope it is what you are looking for.
Please rate this solution.
Product name Kitchen-Aid KUDC03FVSS Dishwasher Dishwasher Style 24" Wide Built-in Wash Levels 3 Wash Levels Wash Cycles / Options 3 Wash Cycles / 3 Options Noise Reduction Insulation Yes Rinse and Hold Option Yes Electronic Controls Yes Food Disposer Hard Food Disposer Heated Drying On/Off Control Yes Rinse Aid Dispenser Yes Tub Type Stainless Steel Tub Color Stainless Steel Integrated Console Yes Energy Star Compliant Meets Energy Star Requirements Dimensions 23.8(w) X 34.5(h) X 24.5(d) Shipping Weight 95 lbs
Mar 06, 2011 | Dishwashers
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Need users manual
parts are longer avaible it is obsalete
Dec 04, 2008 | Dishwashers
KitchenAid KDS-16 dishwasher, leaking from fill air gap
Peace,
If you want to try it okay .
but i think there are more variables and
you need hands on service tech with experiance!
Sep 06, 2008 | Dishwashers
Dishwashers Logo
231 people viewed this question
Top Dishwashers Experts
