My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a MacBook laptop 2GHz Intel Core 2 Duo. I have never had a problem with the drive... The drive does not show up in Disk Utility... Thanks!
  • 1 more comment
  • davestys Jan 08, 2009
    Yes, it does powerup and the disk is spinning. The indicator light comes on. It just won't mount... This disk is relatively new 3-4 years. Light use...
    Thanks for your help - hopefully we can solve this!
    How do I backup the disk if I cannot mount it? Thanks!
  • Bill Speer
    Bill Speer May 11, 2010
    Given that it is only 160 GB (mine is about 4 yrs. old and 250 GB), there is the possibility it has seen its last days. Does it power up? If so, can you feel vibrations from the spinning disc? Let me know.
  • 139 Answers
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
Posted on Jan 08, 2009
Disk is not readable by the computer.
Try a different "data" cable between your computer and the external disk-drive.
Try connecting the unit to a different computer.
If it fails there, then the unit itself has a problem:
Either:
* the USB-to-disk-drive adapter (inside the casing) has failed;
* the disk-drive (inside the casing) has failed.
Disassemble the external unit, and remove the disk-drive. Connect it as a "slave" disk-drive in some Apple Computer, to see if the data on the disk-drive can still be accessed.
Check with LACIE, to see if their "warranty" is still valid, or if it has expired.
Apr 08, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Computers & Internet
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Bought a new LaCie drive; isn't recognized by mac or pc
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Oct 02, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
Lacie Hard drive problem
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. I don't know if you're using a PC or Mac, but try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. If that doesn't work, try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer.
Aug 02, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 1000gb external drive
I own a Lacie product that does the same thing. It uses firewire but it was clicking a few times and then would not display as a drive. I moved to another computer (with a different firewire card) and it worked. I decided that the firewire card was the issue at the time, but the card still read other devices like digital video camera. I know you are using the USB 2.0 cable. Can you try your drive on a different computer? That would narrow the possible solutions down.
Jun 26, 2007 | LaCie (300951U) 500 GB Hard Drive
External Firewire drive won't mount any more
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. Try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. Try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer. From your brief description, it sounds as though you may need to re-format the drive before it will work again.
Apr 11, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
