Question about Watts Onan Portable Generator - 4000 , Model# 5500
6.5KW Onan generator. wont run when the start button is released
Generator runs fine as long as the start button is released, but shuts off immediately as soon as the button is released. Big dollars to get service is there a simple solution and where does one get service manuals
  • 1 more comment
  • rajones2 Mar 21, 2009
    Low oil press switch is ok, 2 brushe look good, clean 2 rings for the brushes, check all connections, How can I test the 2 cards?
    rajones2@verizon.net
  • Thomas F. Schneider May 11, 2010
    Her the download site to get the manual from.
    http://www.cumminsonan.com/cm/support/ma...
  • Anonymous Mar 31, 2014
    generator starts easy but then stopd, It will run if you plug something in. but will not idle. overload button is always on.
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Posted on Mar 23, 2009
Onan 6.5 rv gen set starts buts dies when start button is released
First check the oil. If the oil level is low it will not run. If the oil level is good the generator may not be producing power and you will need to troubleshoot the generator.
Oct 27, 2016 | Electrical Supplies
Cant run both a/c at same time
A 5KW is too small to run two HVAC at once, especially if they do not have interlock relays where only one at a time can cycle. It needs a 7KW for two HVAC units
Mar 16, 2014 | Onan 5500 Microquiet Generator
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
I have a onan 6.5 emerald gen,when you start it it quits as soon as you let go of the start button, will run fine while holding start button on,then quits when you release,please help,maybe field not...
More likely the switch is bad, and only make run contact when in the start position.
Easy to test the switch continuity with a ohm meter when it is not running.
May 06, 2011 | Watts Onan Portable Generator - 5000 ,...
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Wont keep running after start button is released
If the fuel filter is good and lines are good then it sounds like the fuel is making its way to the carb built trash is stopping the fuel from getting into the engine in order to run. Clean out the carb bowl and clean out the valve stem. I know on the Honda unit the valve stem is removed with the carb bowl then then with a striaght screw driver you can remove the Body once you drop the bowl down with the stem so to clean out the cyclinderical body. Good luck
Jul 28, 2009 | Watts Onan Portable Generator - 4000 ,...
Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Apr 10, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,934 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
