Question about Panasonic NN-S753 Microwave Oven
Cracked door on Panasonic S753 combi microwave oven
My Panasonic NN-S753 combi microwave is working fine, but has developed a crack at the top of the white door surround. Is it dangerous to use in this condition? If I can get a new door is it possible for me to fix this myself? Thank you, incompetent housewife.
  • jofenn Jan 08, 2009
    Thank you very much Mr Fixit, I was worried about being zapped. You have put my mind to rest and saved me the expense of buying a new microwave. Great!
    New Friend:
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Posted on Nov 26, 2012
    President:
  • 2,692 Answers
No not dangerous because the shape of the metal is what keeps the microwaves in , not the door. Yes if you could get a door you could change it yourself.
Posted on Jan 08, 2009
  • Thomas F. Schneider Jan 08, 2009
    Your welcome. Thank you for the vote.
  • sue jones Nov 27, 2012
    thank you now have peace of mind tks sue
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Have a panasonic nn sa616w oven - turntable refuses to turn. Have cleaned the oven thoroughly and can't understand why it won't turn.
not sure on panasonic but most of them turn with a little gear drive. maybe the gear is stripped or off location.
Jun 07, 2009 | Panasonic NN-S753 Microwave Oven
Have had Panasonic microwave NN-S753 several years. Worked fine, recently tray started rotating when door is opened to insert food. Despite this problem, unit continues to cook fine after time is set and...
Thanks for that ID number. That's a big help.
Now, looking at the schematic, it's clear that you would have a shorted primary latch switch (top door switch) or that switch's mount is damaged.
For safety, disassembly and diagnosis of door switch trouble, see my generic files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Mar 13, 2009 | Panasonic NN-S753 Microwave Oven
Microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Door does not secure when closed
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Microwave oven NN-S573
The usual cause is the tray motor assembly, or the power supply that feeds it. These parts are available from the parts rep for Panasonic. Contact Panasonic for details.
There are serious safety issues when servicing microwave ovens. I suggest to have the oven professionaly serviced by an experienced service tech for these products.
Jerry G.
Apr 17, 2008 | Panasonic NN-S753 Microwave Oven
Panasonic NN-S753 Microwave Oven Logo
639 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
