Question about RCA F25432 25" TV
How do I hook up a converter box to RCA F25432?
The RCA TV F25432 has two holes in the back, one labeled F and one labeled S. There is also a place to attach the antenna and something called a G link. I purchased a Zenith converter box but don't know how to hook up the cables. I connected converter boxes to two other TVs with no problem. What do you suggest?
Thanks - Carole
  • RCA Master
  • 6,487 Answers
This user manual should be helpful to you, can download it from this link and its free http://www.retrevo.com/support/RCA-F25432-TVs-manual/id/402dj387/t/2/
Posted on Jan 08, 2009
    Sergeant:
    Champion:
  • 304 Answers
Connect the cable box into the Glink input
  • Elizabeth Krijt
    Elizabeth Krijt Jan 08, 2009
    hi cmwallace9,
    If your TV is connected to a cable box you must connect the G-LINK cable to
    receive TV program listings for your area, and to tune directly to a channel when the program
    guide is on your TV screen.
    You have to place the G-LINK wands in front of the remote sensor on the VCR
    Some cable boxes and VCRs have the remote sensor labeled on the unit. If
    isn’t labeled on your VCR and/or cable box, you need to use the remote control
    the VCR and/or cable box to locate the sensor.
    1. Turn off the VCR and/or cable box.
    2. Hold the remote control (not the one that came with your TV, but the
    the cable box and/or VCR to which you’re attaching the G-LINK cable)
    the front of the component.
    3. Slowly move the remote control across the front of the component (VCR
    you press the power button on and off. You must press and release the
    time you move the remote (holding down the button won’t work).
    4. When the component turns on, you’ve located the remote sensor.
    note: If you don’t have both a
    cable box and a VCR
    connected to your TV,
    just coil the cable of the
    extra G-LINK wand with a
    twist tie and leave it
    behind the TV.
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
Hooking up antena & converter box
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Dec 02, 2012 | GE 27GT271 TV
My manavox tv dvd/vhs unit is hooked up to a converter box. All I had to do was turn on the converter box and then the tv. It was working just fine untill I cut if off one day, instead of leaving it on...
  1. Try unplugging the converter box from the power, and RCA or Coax connector. Reconnect the power and RCA or Coax connector. Try turning it on.
  2. Look for a reset button. May be a small hole with a button inside, if you find one use a paperclip or similar to press it.
  3. Try the converter box with a different TV.
  4. If this doesn't fix the problem, replace the converter box.
Feb 22, 2011 | Philips Magnavox 20MC4304 20 in....
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
HOW DO I HOOK UP MY XBOX TO MY CONVERTER
The Converter would need a set of Composite (also called RCA inputs, yellow/red/white) inputs on the back, then it would just be a matter of changing the video source on the converter...
However, seeing as how there would be no additional benefit to hooking up a game console or DVD player through the converter to the TV, I'm not sure why you'd want to in the first place...
Sep 11, 2009 | Insignia Digital-to-Analog Converter for...
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Want to hook up Zenith converter box with RCA F25432 TV
Generally you just use either the F port (used often for cable or coaxial connections) or the RCA (composite) inputs.
Jan 05, 2009 | Zenith C27A24T 27" TV
How to connect DVD
I understand that but on your cable box there should be audio out jacks just like on mine. It will say audio out. On some cable boxes there is a video in. Another way is to go to a local Radioshack or place like that and buy an AV switch. They are about $10-$20.
Apr 23, 2008 | RCA F25432 25" TV
RCA F25432 25in
If you ONLY have an Antenna or Cable input, you are going to need a Video & Audio to RF converter.. This connects to ya DVD Video & Sound OUT, and then connects to ya sets Antenna IN. This device converts ya Video & Audio signal to Radio Frequency Signal that can be "Received" by ya set. (Basically a low power TV transmitter) This is the only way I know of, if ya haven't got any other Inputs into a set.
Aug 15, 2007 | RCA F25432 25" TV
RCA F25432 25" TV Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
