Question about Cell Phones
My phone won't charge. Like sometimes it does but only if you push the charger in really hard but that doesn't always work. Also it loses the charge really fast like within a few hours.
    Sergeant:
  • 290 Answers
Sounds like a bad connector on the charger, pick up a new one and you might need a new battery. If phone is under 1 year warranty your carrier should replace both for you for free.
Posted on Jan 08, 2009
Charge without charger
Try charging it via USB, although it won't charge as fast.
If that doesn't work, your charger dock is broken.
Mar 06, 2014 | Sylvania Sytab10st 10-inch Tablet Black
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
This rumor 2 won't turn on or charge at all. i really need help. thanks
Have you tried taking out the battery and putting it in again? Another thing, sometimes when the battery is completely drained you need to turn on with the charger on (since you can't charge when your phone is off and with no power).
Nov 25, 2011 | LG RUMOR Cellular Phone
Nokia 5130c-2 always charging but when i remove charger battery is low give me solution
Hello.
these symptoms means that a new battery is required.
the phone's battery is exhausted after a long time of use, replace the battery and the problem is solved.
Best Regards.
Jun 03, 2011 | Nokia 5130 Cellular Phone
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
It used to be that i would have to push really hard on my charger for my phone to charge now it doesnt even charge. i push the on button and it wont turn on either! what do i do!
The problem is between the connection of your cellphone and the charger. I think the power has been drained from the battery already that's why it's not turning on.
I have two suggestions:
1. Check the hole in your cellphone where you put in your charger. Maybe, the hole has a problem or any sign of damages.
2. Buy a new charger. Check whether your cellphone works with the charger before buying it just to make sure that it's not your phone which has a problem.
I hope this helps.
Please rate this solution.
Jan 28, 2011 | Cell Phones
My phone wont charge
To fix it , the phone must be taken apart, and a new charger socket must be soldered into the internal board.
This is a precision job and must be done by a technician.
I suggest going to a phone repair shop and asking a quote for the repair.
Sep 13, 2008 | Cell Phones
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
