Question about Philips CDR950 CD Recorder
CD recorder freeezing up
Phillips CD recorder, older model, single deck, stops after 45-50 minutes of recording, any mode. Flashes "update" to "disc error" and unable to finalize. will only play back on recorder. Have tried cleaning lens. Also have tried every CD-R on the market to no avail. Any suggestions will be greatfully tried.
  • 59 Answers
Hiya jeff you have tried a cd cleaner - But also try a DEEP CLEAN Get a screw driver unscrew the 4 or 5 screws 2 at each side maby 2 at the back Lift the lid off ans see inside. Eject the cd tray before you take the lid off as some players lock down when there is no power - anyway With the lid of you will see the lens - SORRY FAIL TO MENTION THE POWER SHOULD BE OFF and unplugged from the mains WHEN DOING THIS.!!!! BUT HOPEFULLY YOU'RE NOT AN IDIOT! lol!! Next ask your girl friend / wife / boy friend - if your like that!! get one of those cotton woll bud's you know the one's with wool on at stick normally used for picking wax from your ear! Now get some Vodka (Not to drink) sorry wet the end of the stick and carefully clean the lens around in a circle within the eye of the lens. then dry it with carefully with the other end of the stick hopefully you will see the dirt on the end you have just removed. after that has been done (do this where no kids are around) leave the lid off plug it back into the mains pop a cd-rw in record 5-10 mins of bbc 1 or a music channel or any thing else you can think of just to test if you have recorded this 10 mins then it's working. Screw the lid back on - and bobs your uncle. let me know how you got on - mail@gogocomms.co.uk Raverbaby
Posted on May 31, 2007
DURNING FINALIZE MODE IT STOPPED WITH1:30 LEFT--- THEN I TURNED IT OFF AND TRIED AGAIN TO FINALIZE AND IT CAME UP WITH A READING OF---REPAIR--
That's a normal response to an interrupted Finalization.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
Jan 23, 2011 | HHB BurnIt CDR830 CD Recorder
Plays fine on both decks, but does not record in any mode.when press rec, the indicator switched from saying "blanc disc" to "data disc" i got this deck used last year. not sure if it...
Check if the blank disc you are using is compatible. It sounds like the discs you are trying to record onto are not compatible with the unit OR you are trying to record in the wrong mode (Synchro v direct see below) It will only record onto CD-R or CD-RW discs. Also read the instructions for recording as there are a number of recording modes depending on menu settings.
See manual here http://www.google.co.uk/url?sa=t&source=web&cd=2&sqi=2&ved=0CCMQFjAB&url=http%3A%2F%2Fmedia.zzounds.com%2Fmedia%2FRCDW500C-be7b6d8b3a46898dae1be148e1af5402.pdf&ei=3eIsTcisNI7sOce8hakK&usg=AFQjCNGCxcLKQKViw1TVJPh_baxuXkVKQA
Jan 11, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
Can't finalize disc
wonder if thers firmware update for that model try anther cd just make sure not bad disk ok maxwell reg ones just fone always burn slower then needed also cheak website for firmware updates if avb
Oct 06, 2008 | Marantz CDR631 CD Recorder
Philips CD Recorder
Have you tried cleaning the lazer lens with a cleaning disk?
May 19, 2007 | Teac CD-RW880 CD Player / Recorder
Philips CDR950 CD Recorder Logo
119 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
