Question about RCA D52W19 52" Rear Projection Television
I am trying to install a new convergence board on my rca d52w19 tv. I cannot figure out where a couple of the wires go. Can you assist me on this.
  • Chuck May 11, 2010
  • 133 Answers
If you are putting in the whole board, you just have to unplug everything off the pld board, then there should be 4 screws holding it in, if you are doing the convergence IC's (there little black chipd, with about 20 wires on it), you will need 2 of them, and you have to turn the boart over, and unsolder the old ones, and solder the new ones, not an easy task, but not real hard eather, thats why service centers charge about 5 hundi to do it
Posted on Jan 08, 2009
RCA D52W19 52 in, as speaker was put beside it & the convergence is out.
Move speaker away, unplug tv for a few hours, restart and do convergence adjust using menus.
Nov 27, 2011 | Televison & Video
Rca d52w19 rear projection changed flyback and cp150 cap. fuse fl231 is good . have bowed screen and 3d effect. convergence shows in menu but cannot adjust at all.
IF the FL231 fuse is good and you still can not adjust the convergence then the Convergence power supply board would be the most likely problem. You can get the replacement boards from www.tvrepairworld.com
Mar 31, 2011 | RCA D52W19 52" Rear Projection Television
My tv isn't clear anymore and the convergence menu won't help eith the color problemscom
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 08, 2010 | RCA D52W19 52" Rear Projection Television
Pictures looks 3 d
The tv have a problems known as a convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 04, 2010 | RCA D52W19 52" Rear Projection Television
Picture showing double vision along with rounding effect!
No,Ur tv have convergence problems.The convergence board.The 2 STK convergence ICS,and some or all it resisitors are dead,require all these componnents parts must be replaced.The shop will cost u $300-350 for parts and labors.
May 19, 2010 | RCA D52W19 52" Rear Projection Television
RCA Model D52w19
One thing that comes to mind is the two main connectors on the power/deflection board. They have ribbon cable in them. If they are white in color. One of them plus the one on the convergence board that is the same size, needs to be replaced. If they are black they are good. Part number is 258686. If your serial number is between G13XXXXXX and G26XXXXXX this is a very good posibility.
Aug 04, 2008 | RCA HD52W58 52" TV
Rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
http://servicemanuals.vstore.ca/
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Convergence problem
when you go into menu do you see covergence in setup,if not then it is not your convergence boards,next to your fiyback transfomer this is the power supply board there is 3 small fuses the one in the middle opens FL231 they look like small brown square caps 0.4 amps.
Jun 05, 2008 | RCA D52W19 52" Rear Projection Television
Convergence issue at screen edge
Sounds like a technician that failed to do the convergence alignment that should be checked after any repair. No nudging needed, maybe just nudge the technician who fixed it.
Feb 15, 2007 | RCA D52W19 52" Rear Projection Television
D52W19 convergence problem
Since this is an intermittent problem, I would first check the convergence board for cracked solder connections or other loose connectors (or leaky capacitors and diodes). If you still cannot find the problem, you will most likely have to replace the convergence board assembly p/n 264103. It can be quite difficult to re-converge if you do this unless you swap the two eeprom IC's on the original board to the new board IK210 and IK211 then Go Into The Service Menu Geometry And Set V Slope And H Position, Save, Then Back Out To the Customer Menu And Run AutoConvergence.
Dec 22, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
