Question about Hotpoint FFA70 Bottom Freezer Refrigerator
How can I unblock my Hotpoint FFA70 fridge freezer
The water is no longer going down the drain at the back of the salad bins. I've tried straw, electrical flex but they hit an obstruction at a depth not far short of the drainage tray. What could I try?
  • help_needed2 Feb 09, 2008
    I've had the same problem and had to unplug the appliance to defrost it, butv within a few days of putting it back on it was happening again.
    Any further suggestions.
  • Anonymous Mar 03, 2008
    Water not draining through drainage hole , hole seems to be blocked. What can I do
I have had the same problem and to solve it I had to turn the appliance off to allow it to defrost as the blockage was caused by the pipe freezing up.
Posted on Sep 25, 2007
  • 3 Answers
Try using a curtin wire
Posted on Sep 20, 2007
The water is no longer going down the drain at the back of the salad bins. I've tried straw, electrical flex but they hit an obstruction at a depth not far short of the drainage tray. What could I...
Greetings,
its most likely ice...take a squeeze bottle or tubing and force water into drain opening. I use a 1/4inch tube and blow into it and then **** some water out and continue this until open...
Jan 06, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Jan 18, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge smells
The drain leads to a pan under the fridge that sits on coils and evaporates the condensate that drained out. you should be able to access the pan and remove it and clean. or you can just wait for it to evaporate and go away. (better off to clean) some warm water in a baster will help rinse out the line. Let me know if that worked or if you need help accessing the pan.
Oct 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Water beneath my salad bin
if the drain is truly not blocked then the water will go down it. try poking a piece of thin wire down it to check, and have a look on the outside at the back - some models have a tray or tank where this water collects that may be full - else the fridge drain should be plumbed into a drain - check from the outside too. Also check if the fridge is truly level. The feet allow you to adjust this and see - sometimes a small change in angle can spoil the drainage characteristics of these machines (possibly even lean it backwards a little if it looks like this might help). the only other possibility is if the fridge drain is fixed into another drain, that another appliance or fixture is causing back pressure - if so you would be able to see bubbling into your fridge if you sat and watched while someone else ran all the sinks/toilets/washers/dishwashers etc around the house - in theory though when all these other items are not running then the water should still drain.
Mar 10, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
532 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
