Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Philips 23pf532-/28 will only go to standby - Philips 23PF5320 23 in. HD-Ready LCD Television
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
Philips 20pfl4122/10 20" lcd not coming on red standby
I have the exact same problem... Only unplugging it completely from the power for about 1 minute fixes it till next time... which is usually untill it heats up...mmmm... Did you find any permanent fix??? Cheers Mike
Feb 10, 2010 | Philips Televison & Video
On my philips tv the red standby light is flashing
hola,tengo un reproductor de musica y a estado parado un tiempo,y ahora al enchufarlo se le enciende la luz de standby en rojo y no en verde como deveria ser.a que es devido este problema?1 saludo y gracias
Oct 21, 2009 | Philips 32PW6506 32" TV
Philips 21'' L01.2A AB Chassis; Dead, Standby LED off.
it.s possibly a fuse, or a resistor, or regulator or all of the above
Jun 08, 2009 | Philips Magnavox 27MS343S 27" TV
Philips - dvp 642/37
Player goes back to standby because the power supply still has a problem.Run checks on semiconducters in primary cct. of chopper transformer.If ok, replace the pulse width modulator.That should fixya.
Jul 23, 2008 | Philips DVP642 DVD Player
Standby
i have a dvd philips,dvp3005k ...no work only red led is on / no display...? I see the switch is good...
Jun 24, 2007 | Philips DVP-3005 DVD Player
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
