Question about Allegro DVD Recorder VCR Combo ABR521
I need program for remote control-AT&T 200b
I need to program AT&T 200B remote to sharp tv(no cable)
Sharp 026 • 091 • 129 • 141
the guide can be retrieved from
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/us_electronics_uf4200c_manual.pdf
On the remote control, press and hold the appropriate mode key (TV button) until the four mode
keys flash twice. The mode key will continue to flash.
Enter the three-digit code. See above I gave all the Sharp codes.
After you press the first digit, the mode key should light and stay on. After you press
the last digit, the mode key should flash three times and turn off.
If the mode key does not flash three times before turning off, the code is invalid for
this device type. Repeat the procedure with another device code.
Point the remote at the device and press POWER. If the device turns on or off, you
have finished programming.
If you have tried all the codes listed for the manufacturer and the device does not
respond, refer to the CodeScan™ section later in this manual.
Posted on Jan 18, 2009
    New Friend:
Http://www.barovelli.com/tv/att200b.htm
Posted on Dec 28, 2015
DYNEX OWNERS MANUAL FOR DX-LCO37-09-2 200B
Try Googling (dynex)(DX-LCO37-09-2 200B)(manual) without parens.
Oct 03, 2017 | Dynex Televison & Video
Datsun 200b
CHECK WITH PARTS STORE. SOME STORES CAN TEST COILS AND RESISTOR.
Nov 24, 2013 | Vehicle Parts & Accessories
Lost my remote to my dvd player gpx model number d2008
Do you mean the GPX D-200B DVD player? A replacement remote is available from Remotes.com, http://remotes.com/remotes/servlet/rs?a=gmi&uuid=13812721273660&smodel=D200B&brand_pn=GPX_D200B . Alternatively, any universal remote that was programmed late in 2013 will probably have the correct codes. (The manual gives a copyright date of 2012. Universal remotes programmed six months after the DVD player was released will usually have the correct GPX DVD player codes. So a remote programmed in late 2012 might work; it will depend on exactly when the D200B was released.)
I hope this helps.
Oct 08, 2013 | Garmin GPS
4 200b chauvet lights stopped working ,blowing the internal fuses when plugged in.
It is never a good idea using LED lights with Triac switches, which I assume if what will be in your remote control unit. Good old fashioned relay units are fine but there is often a problem with triac and thyristor controls as they do not expect the type of load that LED lights present and they often do not switch on properly causing all sorts of issues including burning out (invisibly) interal circuitry.
Feb 16, 2013 | Chauvet Led Colorsplash 200b Dmx Wash...
I have four 200b lights that i must have connected to a wrong device and all 4 blew fuses. I replaced the fuses but they continue to blow as soon as I plug them in.Any suggestions would greatly appreciate.
first need to know if the other device you connected it is with dmx and if not, the most likely need replacement on the circuit 8 pin controller dmx its easy to know the locate its the circuit most close to the input signal, I hope you test the input volt regulators and are well, if not also need more data presents fault.
Feb 16, 2013 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
How to connect power to champion uh-200b single phas
I don't see the date when you posted this problem but it is still on unsolved suport section. So I try to let you know that all Champion dishwashers need the first inital start up . That is make sure water is in the booster , Locate the Installation and service toggle switch on the extreme left side of the control box.Prime the booster .
Let me know if you still want more information about this unit. God Bless,
May 08, 2009 | Champion 24 in. UH-200B Built-in...
At&t 200b remote controller for a mitsubishi tv
I have the instruction sheet for this remote. I scanned and posted it on my site
http://roburt.com/ATT-200B.html
good luck! Robert
Feb 05, 2009 | Allegro DVD Recorder VCR Combo ABR521
Televison & Video Logo
1,463 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Repairing
Computer Repairing
ray gallant
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
