Question about Compaq Presario 700 470024-192 Notebook
Keys dont work right
I have a compaq presario f700 and all of a sudden my enter key won't work then when i am typing it skips all around! how do i fix this?
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have a Compaq Presario f700 running Windows 7 64bit. It freezes up at bootup, unless at the Compaq screen I press the [DEL] button to view the start-up sequence message. Why? How can I fix it?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
May 17, 2012 | Compaq Computers & Internet
I have a compaq presario f700. its caps lock n scroll lock keys are functioning but light is not working wht could b the trouble???
most likely the led is blown.
short of stripping down the laptop to replace the leds,,, a pro job,,, just work away without them
Jun 23, 2011 | Compaq Presario 700 470024-192 Notebook
How can i reboot my compaq presario f700 to factory setting
hp/compaq usually have built in recovery, just keep pressing the f11 key as you power up the computer untill it enters recovery mode (some of them use the f12 key)
Apr 03, 2011 | Computers & Internet
I just got this Compaq F700 from brother in law and the keyboard is messed up. When I type it jumps all over and puts letters in between other words. What is the problem and can it be fixed?
Try cleaning under the key with a tin of contact cleaner,do the keys feel stiky when you press them?
other than that get a new keyboard off e-bay for about £10 - 20
their a pice of pi*s to fit.
Giz a shout if you get stuck djtatty@hotmail.com
Sep 27, 2010 | Compaq Presario 700 470024-192 Notebook
I have a Compaq Presario F700, how can I activate s-video out?
On most laptops it a simple case of pressing two buttons together, usually th 'FN' or 'Function' Key and 'F5' (press fn first, hold down then press f5) Yours maybe slightly different and use a different F key ie F3.
Nov 22, 2009 | Compaq Computers & Internet
My compaq presario f700 laptop boots when it wants
Your system is damaged. You need to have Vista cd. (or xp, or linux, etc) Then you must get to Bios, or bootmenu. When laptop boots, it is on a screen what key to press to make bios or menu running. Maybe f2 or del, maybe f12. When you in Bios, search something like bootmenu, or advanced bios features, then - first boot device. Make it as -cdrom. Press enter or maybe page up/down to change it. Now you must save this by pressing f10 or some key for save, and pressing y. Comp will boot again and run from Vista cd. In its menu you have option repair, but not always this will work (If you doing it with xp, forget to repair Vista). Try this, and if not working, reinstall system on the same partition. Dont format drive, just install, it will give you no loss of data (with xp, i dont think so, you just have to format system partition, but if you have something on second and more, non system partition, dont format it, data on this second will be ok). This it for instalation. After, you will have old vista in some folder (With xp you dont). You should delete this folder when everything works. Do not delete the new one :) No, no, you will find it easy, it should be something like -oldwindows. Better to remove it, cos' it takes a lot of hd. After it all try to find some good antivirus to avoid situations like this.
Apr 09, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario f700 enter key will not work and while typing it skips around
I have a laptop where the enter button and delete button dont function(and I know why cos my brothers mrs soft cow spilt wine over the keyboard) anyway it dont bother me much cos I use the mouse for most things ; but if I need to have use of enter or delete I either plug in an external keyboard or I use the on screen keyboard. (start...all programs....accessories...accessability)
you can also get a roll up keypad,usb.last option you'll have to go ebay for keyboard
Jan 08, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
