Question about Alpine MRP-M350 Car Audio Amplifier
Amp keeps shutting off
I have 2 subs hooked in to a alpine mrp-m500 amp. I had 3 subs, two 10s and one 12. It seemed like it was over loading and shutting off then i took the 12 out and left the two tens in and worked fine. Then yesterday i turned the power level on my deck on and was blasting it for like a few minutes. Then the amp just did the same thing, the light stays on but it juts doesnt work untill i shut the radio off and turn it back on and i need to keep it on really low or else it dies.
  • 3 Answers
You dont have it bridged right your dropping your ohms down way to low.. when you go to bridge your amp you have a negative and a positive on your amp thats it i have an alpine v-power mrp-m350 i think there identical should be but anyways you have to buy a Y splitter there RCA JACKS its has the 2 ends that plug into your amp than ties into a single one its a male or female adapter the place were your gonna get it w know the trick of these amps when bridging is only keep your left channel cable plugged in to your cd player i think its white colored dont plug the other one in rap tape around it or get a rubber cap and put over it.. run your RCA cables to your location of amp location and do the same just tie that into your left channel and tape or get a rubber cap to put over the other one i wish i could draw you a diagram of it hard to explain when typing it if you have a cell phone or house phone i would prefer you calling me from a cell so i dont get charged a fortune my cell number is 1814-594-2667 call me i will get it working for yeah hope to hear from you soon my name is Brad
Posted on Jan 10, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
Wiring alpine amp and sub
To wire your 4 ohm dual voicecoil to a 2 ohm mono load - all positives to + on amp.... all negatives to - on amp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
I got to 12 they are about 400 watts each what would be a good amp to put on it to lift the subs
Hello jeremymikjha,
Basically you want to match the subs in impedance and power.
With 4 ohm subs wired in parallel, the final load will be 2 ohms. Depending on how hard you want them to hit, a pair of 400 watt RMS subs will need an amp that delivers 600-1,000 watts into a 2 ohm load.
The enclosure you use will also make a big difference. A sealed enclosure will need more power. A ported enclosure will be louder with less power.
The Hifonics shown here would be a good choice for a sealed enclosure. It's rated for 1,100 watts RMS into a 2 ohm load.
http://www.sonicelectronix.com/item_17598_Hifonics+BXi+1610D.html
The Eclipse XA1200 outputs 600 watts RMS into a 2 ohm load. It would power the subs very well in a ported box.
Somewhat less expensive but good quality would be one of the Alpine MRP series. The MRP-M500 is only $179.99 at SonicElectronix. It delivers 500 watts. It's big brother is the MRP-M1000 with twice the power. Be sure your subs are securely mounted or this amp will literally "lift the subs".
Hope this helps.
Oct 19, 2009 | Rockford Fosgate Punch 301M Car Audio...
Brand New MRP-M500 light is on but there is no sound
Try making sure your sound input to the amp is good (could be a bad output from the radio or RCA cable), could also be a bad input from the amp, bad outputs from the amp or even a bad sub. You have to check each of these and eliminate the problem. I would make sure you have a good audio signal to the amp first.
Sep 05, 2009 | Alpine MRP-M500 Car Audio Amplifier
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Alpine MRP-M350 Car Audio Amplifier Logo
258 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
