Question about Odyssey Drive 4-Wheel Scooter - Color Blue
SCOOTER WON'T GO BUT 2 MILES HOUR NOT 7
MY SCOOTERS WILL NOT GO BUT 2 MILES HOUR, ITS NOT THE BATTERIES
  • Dan Hudson May 11, 2010
    Is this a Pride product? I would check the voltage to the motor, then the voltage going to the controller. At this point it coujld be many things.
  • 103 Answers
Be sure that the batteries were tested with a load tester. If it is not the batteries then ohm test the brakes. It should be around 35 ohms.
Posted on Mar 09, 2009
My Sym moped starts but won't idle It shuts off when trying to give it gas
Hi, Gigi and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Scooter Questions Get Answers to Your Scooter Starting Question
Scooter Troubleshooting Scooter won run All about Scooters
My chinese scooter wont idle or start Check the fuel petcock
http://scooterunderground.ca/knowledge/manuals/documents/sym_fiddleii125_service_manual.pdf
Oct 01, 2016 | Sym 125 EXC SIXDAyS Motorcycles
Replacement Batteries. Can you find me a dealer
http://www.mtmmobility.co.uk/mobility-scooters-c1/used-mobility-scooters-c46/one-rehab-landlex-rs400x-8mph-road-scooter-p49 The Following products are available for free, Please select one of the following:
    • Pneumatic Tiller
    • Automatic Headlight
    • High Back Deluxe Seat
    • Delta Tiller
    • Good Condition
    This fantastic 8mph Class 3 road scooter is in very good condition, regularly serviced by MTM Mobility. With a reclining captains seat, full suspension and large wheels this Landlex Broadway RS mobility scooter with its quality 36ah batteries capable of up to 20 miles will give you all the comfort you need.
    https://www.batterybuyer.com/advanced_search_result.php?keywords=scooter+battery&osCsid=f50e0545c596ecdb777870d740d3cb39
    Oct 07, 2015 | Health & Beauty
    Mercury prism mobility scooter
    The distance a scooter will go depends on the size and weight of the load also. If two people are different height ( wind drag ) and different weight or there is a difference in load you are carrying then there will be a difference in how long the charge will last. Since you switched the batteries with no change then this could be the case. There are other factors that can cause this as well , such as brake dragging, wheel bearings going out, low tire pressure if your tires are air, if 4 wheel scoters then wheel alignment. hope that helps.
    Jun 06, 2013 | Health & Beauty
    How do I test if the batteries are still working? I have not ride or switch on the scooter for at least 3 years.
    Assuming you don't have a voltmeter and can't check to see if the batteries are producing 12.6 volts, remember that these batteries are around $36 each at Radio Shack and easy to replace if your hands are working. If it's really important, spend the $36.
    If your hands don't, or you don't have a Radio Shack, a scooter replace shop locally charges $85 an hour, min one hour, to troubleshoot and diagnose the batteries, then will charge for the parts at around triple the Shack price. I'm sure there is a repair facility similar around your area.
    To test the batteries without a voltmeter, charge the scooter overnight, get on in the morning, and starting at the slowest speed, go forward a little bit, slowly working your way up to the full speed. Stay around your charger, IOW don't go for a 3 mile ride, until you know if and how much of a charge the batteries are holding.
    One last thought, in our scooter, new batteries only lasted 2 years and 2 weeks before losing their capacity. Our local "small town" Shack had the batteries in stock, so they seem to be a popular item.
    Jan 29, 2013 | Pride New Mobility Victory XL 4 Wheel...
    My aunt recently bought a secondhand scooter shoprider us pat no 4798255 without a users manual and the scooter will not charge please could you help?
    Kathryn Was the scooter working when she bought it? If the batteries were fully charged and now it won't charge then I would suspect the charger. If the scooter wasn't charged when she got it and won't charge then I would replace the batteries Hope this helps
    Apr 25, 2011 | Health & Beauty
    I replaced new battery but still the scooter runs slow
    The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
    Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
    I hope this helps; remember to rate this answer.
    Oct 04, 2010 | Razor E300 Scooter
    I have a scootamart large scooter,not sure if 6 or 8 mph.batteries have been checked and are perfect but can only travel 5 or 6 miles on a full charge.what can be wrong.
    Hi. How many amp/hours are your batteries?
    Who tested your batteries, and how did they test them.
    I have had batteries tested by an auto electrical technician, who said the batteries were OK. I knew at the time that the batteries were faulty.
    What he did was do a short high current test, that he would normally do on a car battery.
    To test batteries in a scooter you have to do a constant current test on fully charged batteries, and monitor the battery voltage. When the battery voltage drops to 10.5 volts across the 12 volt battery, that is considered a flat battery. Take the time elapsed for the test, and you can roughly work out the amp/hour rating of your batteries.
    The amp/hour rating of a battery is worked out on a 10 or 20 discharge. A 40 amp/hour battery can supply 2 amps/ hour for 20 hours.
    If you take 20 amps per hour, you will not get 2 hours of use. You will probably only get 1.5 to 1.75 hours of use. The more current ( amps ) you take out of a battery, the less amp/hours it will supply.
    The best way to test your batteries is a constant current test, but they take a few hours, or try new batteries.
    Also how long do you charge your batteries for. Most chargers need to be on at least over night to fully charge your batteries.
    Some chargers have a green LED that comes on when the batteries are nearly full. This green LED is a guide only, and most batteries still need a few more hours to do a full charge.
    Good luck. Neil.
    Jun 10, 2010 | Health & Beauty
    Batteries die fast on my mobility scooter.
    Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
    17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
    Buy the biggest that will fit into the available space.
    Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
    The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
    Good luck. Neil.
    Jun 03, 2010 | Electric Mobility Pacesaver Electric...
    I have XL8 and need to replace batteries, what is the amps strength to give me greater miles, Im a big guy and need to go further than just a few miles
    hi, according the manual
    http://www.pridemobility.co.uk/docs/UK_Celebrity_XL8_om.pdf
    the batteries are
    Battery Requirements
    Size: U1 (31-36 AH)
    Weight Capacity 181 kg, 28 stone (400 lbs.)
    Range Per Charge1 (With 31-36 AH batteries) Up to 40.23 km (25 miles)
    You can use 40Amps batteries for this scooter and that will increase the total distrance to 27 miles max depending on your weight.
    Regards
    GeWiz
    Jan 18, 2010 | Pride New Mobility Legend 4 Wheel Scooter
    Schwinn S350 Scooter batteries
    Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
    Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
    Odyssey Drive 4-Wheel Scooter - Color Blue Logo
    104 people viewed this question
    Top Odyssey Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you an Odyssey Health and Beauty Expert? Answer questions, earn points and help others
