Question about Zenith VRB420 VHS VCR
NO POWER ,MAKING A TICKING SOUND IN POWER SUPPLY
GO VIDEO VCR MODEL # GV3070X
  • marvin_allen Jan 11, 2009
    THANK YOU, DO YOU KNOW WHICH COMPONENT IN THE (PS) ARE DEFECTIVE , I'LL MAKE THE REPAIRS IN VCR MODEL GV3070X.
    Genius:
  • 1,199 Answers
This is a sure sign the power supply needs replaced and is damaged!
Replace power supply and all should be fine again!
PLEASE rate my response to your question!
Thank
You!
Posted on Jan 08, 2009
Vizio e221-a1 not power on making a ticking sound
Blown capacitors on the main power supply board , need to be replaced or easier replace the whole board may be difficult to obtain though
Jul 08, 2014 | Televison & Video
Power supply has a ticking ticking blank screen no pix or sound
Sounds like a shorted H-out, likely due to a bad Flyback. That "chirping sound" is from the o0vercurrent protection in the power supply due to a short. Perhaps it is also a bad capacitor in the supply causing overvoltage shutdown too.
Apr 04, 2014 | Proscan 123882 Power Supply
We have 20 extensions and 12 direct line and all the extensions are making a very light clicking sound, when we press 9 for outgoing line it displays message 'CO not assigned' and justs beeps. People...
The ticking doesn't sound good. Your dealer can probably help you, or you can help yourself if you're familiar with all the cabling. Start by disconnecting all but 2 lines and all the Amphenol cables but the bottom one (J1) on the base cabinet. The key is to isolate if you have a cabinet power supply problem or a bad station (shorted) port. By default, 81 on the intercom gets you line 1. If the ticking is still present with only one cable plugged in, try unplugging J1 and plug J2's Amp into J2.
There are other combinations and variations, mostly things like stripping off the extra trunk and stations cards, but if the basic still leaves you with a ticking, I'm voting for the power supply.
Carl
Dec 23, 2010 | Panasonic KX-T7431 Corded Phone
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
My 93 acura legend wont start. Ticking sound??
That sounds like a dead battery. The ticking sound is the relay (a type of switch) which enables power to the starter motor when you turn the key. If the battery is weak, the relay will click, but there is not enough power to turn the starter motor.
Oct 07, 2009 | 1993 Acura Legend
Tv will not come on
Power Supply Board.. most likely circuit Q777.
http://www.tvrepairkits.com or partsstore.com
Q777 is a PANASONIC C5413. bout 20 bucks.
Mar 15, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Dell GX270T won't boot, makes 'ticking' sound
Well old retired guy there is so many moving parts in a computer. the fans , on the processor ,the power supply, and one on the box of some.You have the cdrom , the a:/ drive and hard drive.You can unplug everyone except the power supply and it will still turn on. If the ticking still exist then its electrical snapping in the power supply.There is more than one voltage coming out of the power supply. Part of its 5 volt and part of it is 12 volt so then part of the supply could be working and another part not working.My guess is get a used power supply and it will work fine.
Another old retired guy
God Bless You Greg
Nov 29, 2008 | Dell OptiPlex GX270 PC Desktop
High pitched squeal coming from power supply on my philips VCR
hi , i am a hardware engineer in the uk here to help if i can, the vga, doesnt normaly squeel , i have not heard of this problem , is the graphics card pci or does it go into the brown slot,if its pci the try change the card to a new one if its a brown slot where the card goes it may be the board slots blown as you say the vga only works for a few moments , see if that helps regards steve
Mar 18, 2007 | Philips Refurbished POWER SUPPLY 50/60 HZ...
No picture, no aundio
most tv/vcr combo has only one power supply source which is located in the vcr unit. u have a power supply circuit problem. try to check the rectifier, filter capacitor and the regulator ic/transistor. good luck!
Feb 02, 2007 | Toshiba MV13L2 13 in. TV/VCR Combo
Zenith VRB420 VHS VCR Logo
208 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
