Question about LG WM-1832C Front Load Washer
Troubleshooting your problem LG Washer
If the machine won't spin, it is either your stater or circuit board that is the problem. The only way to find out which is to run the washer with a different circuit board and see if it fixes the problem. Probably need a technician for this. If you want to run a diagnostic of the machine: DO NOT HAVE CLOTHES IN THE MACHINE FOR THIS. -Hold down "spin speed" & "soil level" buttons, press Power while these buttons are being held. -Press dial:should lock door -Press dial:should begin to spin (rpm should show) -Press dial:should begin to spin faster (rpm X 10 being shown) -continue to press dial which will bring you into filling up, filling up pre wash dispencer, softener dispencer, liquid bleach dispencer, until machine drains. If anything is wrong during these different cycles, the error code should come on and you should have a better idea of what is wrong with your washer. note: you have to keep pressing dial to go into next cycle, it doesn't run itself through the different cycles.
  • sunny2630 Nov 15, 2007
    My problem is similar. It will go thru the wash cycle - and drain, but when it gets to the actual spin cycle, it just grinds. I then get an OE message which would indicate that I have a drain problem. However, my washer will drain during the wash cycle? I have checked the drain filter (nothing). Any suggestions?
  • 105 Answers
You may find that you need to dismantle the pump as you can get things inside the impellor area causing intermitant problem
Posted on Jan 28, 2008
Why does whillpool washing machine not want to spin
Is it a top loader? If so, the drum may be out of balance re-arrange the load so that it is about even all the way around and try again. or ..
Troubleshooting Washing Machine That Won Spin DoItYourself com
Why Won the Whirlpool Washer Spin or Drain
Jul 23, 2018 | Washing Machines
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Sep 22, 2012 | LG WM-2032H Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
I have an LG WM0532HW front load washer. The washer drum has stopped in the middle of a cycle and it show the UE symbol indicating there is an unbalanced load. At this point my clothes are in a drum full...
I would replace the sensor on the stater. I have replaced that a couple times for this problem and it has solved the problem. If you remove the back then take off the main drive you will see the stater and you will see a small sensor on it. Change it and you will probably solve this problem. The part is about $25.00
Mike Anderson
Anderson Appliance
Feb 18, 2010 | LG WM-2277HW Front Load Washer
Ue error code on my LG WASHER
Hi there
hope this helps you .
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board thank your for writing to fix ya.
Best regards Rich
Dec 08, 2009 | LG WD-16115FD Front Load Washer
LG WM-1832C Front Load Washer Logo
1,130 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
