Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Flashing lights cheacked inlet and outlet water pipes,cleaned filter.prewash light comes on when swichting on then rinse light and prewash both flashing.please anyone tell me what that means?
  • DILIP PALMAR May 31, 2007
    please anyone have a solution?
  • 183 Answers
Not heating, check element and thermal fuse/thermostate. Regards Advisor
Posted on Aug 31, 2007
SOURCE:
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
Apr 10, 2014 | Hotpoint WMA50 Front Load Washer
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Miele g 646 sc (not plus)
check the inlet where it joins onto the tap as mine has a fine filter and debris from the fresh water builds up. Simply remove the pipe from the tap and **** ,this should remove /dislodge any scale etc that could be causing the inlet light to come on. Make sure you spit out the water that comes back from the machine!
Apr 20, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Dishlex Global 300 - stopping mid cycle
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Mar 19, 2008 | Dishwashers
Prewash flashing and machine Overfilling
Their is a small bowl connected by a see trough plastic pipe leading up to the preshour switch, that you will have to clean out the bowl and disconect the pipe from the presure switch and blow trough this to clean out any droplets of water. Replace then try the machine again, it may fill up again, dont dispair, empty the machine and re-blow trough the hose again with it disconected from the preshure switch. To empty the machine of water place the outlet hose into a bucket 3 or 4 times.
slimjim1
Oct 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
LG wm1832cw Washer IE error
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. When u hav rinse problems, it is usually the outlet filter.
Sep 11, 2007 | Washing Machines
Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Jul 11, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Jun 06, 2006 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
503 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
