Question about Refrigerators
Water is pooling in bottom of freezer when it defrosts
  • 2,692 Answers
The freezer drain lne is stopped up. Leads to an evaporation tray usually under the unit.
Posted on Jan 07, 2009
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Ice pooling in bottom of frostfree freezer
Sounds like the drain tube(s) which carry the defrost water from the freezer and refrigerator to a catch pan at the bottom of the refrigerator are stopped up.
I have seen these drainage tubes stopped up with debris which prevented the water from draining out. This defrost water can be turned into ice which blocks the defrost drainage even more so.
Oct 09, 2009 | Refrigerators
Water dripping in to freezer bottom ten pools on
Sounds like you have a drain that is plugged. When it goes into defrost the water hass no place to run. Thats when you get water like that. I would defrost it completly. Then try to get to the drain and pour hot water slowly to see if it goes all the way down to the pan. If not. Yu may have to have air pressure to go thru the drain.
Aug 30, 2009 | Refrigerators
Water leaking out the front freezer door... the bottom of freezer unit has water pooled in it frozen... melts and runs out the door
The defrost drain hole in the bottom rear portion of the freezer is frozen shut. Turn off the fridge,use a hair dryer to defrost the drain hole. Pour a 1/4 cup bleach into the hole after is is cleared out. Turn the fridge back on.
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
