Question about Whirlpool GS6NBEXR Side by Side Refrigerator
ICE DISPENSER WATER LEAKS AFTER THE CUBE DISPENSER IS FULL OF WATER & FREEZES ON TOP OF THE CUBES INSIDE THE BIN. IT IS LIKE THE WATER SPLASHES OUT OF THE BACK. I REPLACED THE CLEINOID ON BACK OF THE REFRIGERATOR, BUT CONTINUES TO LEAK
    Problem Solver:
  • 5 Answers
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Posted on Jan 18, 2009
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Sub zero 532, ice maker issue. water enter the cube bin freeze into a block of ice with the cubes embedded. What is the cause of this issue?
There is a few things that you will need to check to isolate the problem. this first thing is locate the fill tube where the water comes into the ice maker. What you are looking for is any ice frozen inside causeing an overspray of sorts. If that checks good, then the next thing is look at the icemaker itself. Look at where the water goes to and freezes. Is it completely full of frozen water? if so then the water valve is sending too much water either because the ice maker called for it or the valve stuck and didn't close when it was supposed to. If its not full, look at the bottom of the ice maker, checking if there are any cracks allowing water to fall into the bin. My personal opinion though would be to change the ice maker and the water valve because of the age of the machine. the bad part is the actual icemaker for that model has been discontinued but I believe you can use a whirlpool style that matches, comes in a kit that has both the water valve and icemaker, and cost almost half the price as the original. that part number is 1129313
May 21, 2012 | Refrigerators
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Leaks into cube bin and freezes up
don't understand what you mean,if you're saying water is dripping into the ice maker more than it should you have a bad water valve,
Nov 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
203 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
