Question about Humax L3040 Television
MHEG application When setting a prerecording from the TV guide, it sometimes does not playback the picture, only get sound and a greyed out screen display with the letters MHEG
0 characters
1 Points
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Flat Panel Televisions
Tiny "guide-size" screen remains when I'm out of guide
I'll let you know if there is a mnual available online for your model.So that you can find out some troubleshooting steps.
Apr 16, 2008 | Philips 42PFL5332D 42 in. LCD Television
Grey border down sides of picture while on AV1
Assuming it's not your device causing the grey lines, just change your aspect ratio settings. Each input has a different set of settings that you can change, so don't worry about messing up the settings on your HMDI 1 input for example if you change your AV1.
Jul 04, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
TOSHIBA 32bv500b screen stops working sound works fine
I'm having a hard time finding any parts for the set besides the power supply board. The T-Con is usually located top center on the back of the LCD panel. It will be under a metal cover. Sometimes, the t-con circuitry is built onto the main board. If this is the case with yours, you will have to order the main board. Feel free to send me a pic of the back of your set.
Jan 06, 2013 | Toshiba Flat Panel Televisions
Why does a grey screen and no picture appear when i turn on the tv??
You haven't given the exact model number to your Hisense TV here, so I assumes that your TV is a picture tube based one, and posts this solution. Your TV has some bad solderings at the video-IF section. Normally all TVs nowadays, this section will be composed with an integrated circuit [IC]. If you have skill in soldering techniqe, just open your TV, and resolder all the solder points of the main IC, which will be a large one, without making any solder bridge short in between adjecent solder terminals. The IC will heat up to an extent, and repeated heating and cooling may make solder terminals to get loose contacted. This is a common problem to almost all TVs irepective to which brand or model it will be.
The problem to your tV now, is with some loose solder terminals itself. OK.
Feb 02, 2012 | Flat Panel Televisions
Philips TV 42pf9976/37 no picture, just grey screen We lost the picture on the TV and it just shows a light grey screen,no wavy lines, fuzziness just plain grey. When you change channels you do get the...
Please try the DVD function to see if you have the same problem. The TV has the backlights working OK and you can also see the Graphic on the screen, you can also see the on screen menu setup right?
Please post back on what you find when you try out the DVD, otherwise you may have bad amin board.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Oct 13, 2011 | Flat Panel Televisions
Tv goes on and then picture and sound go off at same consistent time interval.....sometimes the screen is not fully illuminated...sometimes when the picture and sound go off, the power light...
There are two common possibilities that are causing this problem, dying power supply due to bad DC filter caps, or shorting out backlight inverter board, you will have to do in-depth troubleshooting to narrow down the problem. Please read my guide see the pictures so you can decide if you will want to DIY repair or not.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Failed TV and Monitors:
Sep 01, 2010 | Toshiba 32HL83 32 in. LCD HDTV
Black screen/No TV Guide
Mine is doing the same thing. It's under warrenty and a guy is coming to look at it today. I will post more info once I find out more. I had called LG and they told me it's a problem with Gemstar and an upgrade that is going on with them. Not a TV problem. We will see.
May 17, 2008 | LG 50PX4DR 50 in. Plasma TV
RCA 26" SRS WOW has a grey shadow display when watching TV
yeah, I just got one of those and when the picture is full screen I see that also. I just have the picture set to 14:9 and the pic is crystal clear. any good resources for a wall mount?
May 29, 2007 | RCA LCDX2620W 26 in. HDTV-Ready Television
Humax L3040 Television Logo
32 people viewed this question
Top Humax Flat Panel Televisions Experts
 Mike M
Mike M
Are you a Humax Flat Panel Television Expert? Answer questions, earn points and help others
