Question about OEM Systems PIXMA iP3300 Photo Printer
I cant start even deep cleanining. Before that more than 50 printed sheets (A4 Matte coated Inkjet paper ) were whit awful raster of picture. Help meeeeeee
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
My Dell 942 printer will not pull the paper into the printer, unless the sheet is pushed in very far. The roller spins but does not grab the paper. Any thoughts? For one sheet I can print with the added...
If you use coated or matte paper at all, it will slowly put a coating on the pinch rollers, causing the problem you describe.
Get some isopropyl alcohol and lint free rags and clean the rollers thoroughly. That should solve the problem.
Oct 11, 2009 | Office Equipment & Supplies
Error 6502 PIXMA iX 4000 with CISS
Ok there
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Jan 07, 2009 | OEM Systems PIXMA iP3300 Photo Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Can't print bus. cards
You have solved your own problem with out even knowing it. The heavy paper is what is causing your problem. The solution to most problems is not to panic step back take a few deep breaths. Then kindly ask God. PS Also Thank God. I am just a Poor Sinner but God is my witness.
Jul 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Photo printing
hi doug
I had to reread your first post the mention of what to do with all the photo paper. I see you mean that you don't use matte photo paper you use matte heavy weight paper. I guess I mean that as a question! That is the only thing that works for me with no smearing problems. I haven't found one that is thick enough for a good feel. I used an avery matte paper that has a coating for photo but it just feels very light. Doesn't smear and looks sharp but very light weight. What brand do you use ?
post in me back
oke, thanks
cropp
Mar 11, 2008 | HP Photosmart 7450 InkJet Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Paper Jam with no Jam
You may have overloaded your paper feeder with heavy card stock and caused a very tiny jam that you have not found yet so that it will act oddly as it is. Look right up inside unit with a torch and down back where the paper goes in.Try printing on plain a4 agian, place a small stack in feeder, reset paper guides too. Also could be your paper sensor, fixable under warranty.
Aug 12, 2007 | Epson Stylus Photo R220 InkJet Printer
OEM Systems PIXMA iP3300 Photo Printer Logo
Top OEM Systems Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
Pamela Leach
Pamela Leach
Are you an OEM Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
