Agitator Dogs tangle clothes
Everytime I wash something with strings or something like bras the string gets wrapped around the agitator dogs and center agitator bar and tangles the clothes and leaves them a wrinkled mess. Is there something to correct this issue? The agitator dogs have a small space where the string gets caught. Can we cut them off to prevent this? Will the washer still agitate the clothes correctly?
  • 15,935 Answers
No - The clothes will not agitate properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Clothes get tangled around agitator
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Apr 12, 2015 | Washing Machines
Why does the agitator keep getting stuck and will only go one way
Mar 26, 2015 | Washing Machines
The agitater is not solid and clothes catch under the arms on the bottom and tangle and have even ripped. What can be done about to stop this? It seems like a design flaw to me.
It is not the best of designs.
Sometimes, clothes will get stuck at the bottom when the agitator dogs are worn out. Check to see if the upper part of the agitator is working during the wash cycle. If it isn't, the clothes stay at the bottom and just move horizontally, not from the bottom to the top. The clothes then get stuck in the gap between the lower agitator vaens and the bottom of the agitator. This is a very easy repair, you need only a socket wrench set (SAE) with an extension.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/2744
You can also buy the dogs (pawls) by themselves in a pack of four for about $5.
When I first saw this agitator set-up, I asked myself, 'What were they thinking of?'.
Good luck.
Mar 09, 2011 | Estate TAWS800JQ Top Load Washer
Agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
May 13, 2009 | Washing Machines
Clothes wrapping around centre spool
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Jan 22, 2009 | Washing Machines
Washing Machines Logo
800 people viewed this question
Top Washing Machines Experts
