Question about Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
  • 13 more comments
  • tbroome1988 Jan 08, 2009
    I have plugged my laptop in but nothing happens. It's just a black screen. I did just notice that the battery light is blinking, so, could this be the actual plug in itself?
    No, I haven't tried to pwer the unit with no battery.
  • john6159 Feb 10, 2009
    i have the same problem. i have tried to power up the machine with no battery and it still will not turn on
  • Anonymous Feb 16, 2009
    I was on my laptop acer 5920 then it just shut iff, and now it wont turn on. The chrager light keeps blinking idk what to do. please help
  • atailor Feb 21, 2009
    Power adapter light just blinks and no power to laptop
  • lauren_jade_ Feb 23, 2009
    i have the same problem one day u was just using my laptop normally and it started beeping to tell me battery was flat so i plugged in the charger and it kept beeping then died now it wont trn on the battery light just flashes!! ive tried different chargers but still the same problem.. ive tried without the battery but it switches on for about 2 seconds then switches off again if anyone knows what the problem is please help me!!
  • jzx100 Mar 04, 2009
    i have this same problem, any one know how to fix it ?
  • purplelad701 Mar 10, 2009
    I have an Acer Aspire 5920 and it worked fine until today.  The thing won't turn on, black screen, zero power.  The charger light is a steady green until I plug it in to the laptop then it starts blinking green.  Called Acer and got no where.  Of course, my warranty expired 2 days ago.  Go figure. Has anyone found out for sure what the problem is or what the solution is? I'm guessing the battery is shot.  Any help is appreciated.
  • Anonymous Mar 29, 2009
    I have the the same problem
  • chlo07 Apr 01, 2009
    ahh my laptop was fine all last night i switched it off as normal no problems, go to turn it on today and nothing! no power to the actual laptop when its plugged in!!!, whats going on it was fine last night till now??? someone help me!!
  • Anonymous Apr 07, 2009
    yeh i have the same problem...their is no power on my laptop what so ever(battery completely dead) but the light on my power adapter is flashing...but when i disconnect the power adapter then the light on the power adapter stops flashing and stays green... what does it mean???
  • SaVeewa Apr 24, 2009
    The power adapter is Doing the beeps when it is plugged in. If you listen to the laptop up close it is beeping as well. Has anyone tried to change out the power adapter? I broke the laptop down. I see no damage to the board. Reseated the CPU and heatsink. Debating if i should get another power adapter.
  • Anonymous May 10, 2009
    i have the same problem. was using it like normal, and all of a sudden, just shut down. the power adapter flashes green when i plug it in, but when i take it out of the laptop, it stays green. any help would be appreciated!
  • thebostoncem May 11, 2009
    Same problem as everyone else. Comp was working just as it normally does then all the sudden shut off. no battery power and no power coming to computer from power adapter. Will not start up and the power adapter either has a solid green light, blinking green light or is beeping. Need help very much. please.
    yes, i've tried with and without battery
  • Whodatbe May 11, 2010
    Have you tried to power the unit with no battery?
  • 741 Answers
Try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Posted on Jan 08, 2009
Try holding down the power on button for a full minute with ac or battery power to the unit. This resets the pc, sometimes.
Posted on Mar 25, 2010
Acer aspire 5920 laptop wont turn on its has power going in but wont turn on
Posted on Dec 20, 2012
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
My Acer 5920 Laptop is about a yr old. It is not switching on. The power light blinks for about 5 secoonds and then nothing happens. Please let me know if anybody has a solution to this.
Try removeing the battery, memory and Hard drive. Press and hold the power button for 30 seconds.
Re-install and reseat memory Harddrive and battery.
Try powering up the unit without the battery and any external devices.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Aser Aspire 5920 Will Not Switch On
it must b some problem with the RAM......get the ram changed ...den it will work fine
Sep 02, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Laptop will not turn on
Unplug the AC adapter and remove battery. Hold the power button down for 20-30 seconds. Put the battery back in and reconnect the AC adatpter. This is called a power cycle reset. you may have to do it a couple of times. If that doesn't work email me back and I'll try to assist you.
Aug 02, 2009 | Acer Aspire 5920 AS5920 Notebook
Notebook not turning on
the adapter plug could be bad
there is no way to test it with what you have there
but you can look at the pin in the laptop where it plugs into
take a toothpic or something, and see if it moves loose
if this pin is loose at all , the connection is broken
a new jack is 5 bucks on ebay , but putting it in is some work
also if the laptop cuts on and off if you touch the plug and jack , then it is probably the jack or inside the plug of adapter
Jul 21, 2009 | Acer Aspire 5920 AS5920 Notebook
My Acer 5920 will not run plugged in or unplugged
Your power brick itself blinks? If this is the case, you have a short in the cable someplace. Your best option is to purchase another power cable, ideally from BestBuy or Walmart (someplace where you can return it, just in case)
You shouldn't pay more that 40 dollars for this.
May 01, 2009 | Acer Aspire 5920-6423 Notebook
Acer Aspire 5920-6727 Notebook Logo
8,762 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
