Question about OEM Systems PIXMA iP3300 Photo Printer
Error 6502 PIXMA iX 4000 with CISS
I cant start even deep cleanining.
Before that more than 50 printed sheets (A4 Matte coated Inkjet paper ) were whit awful raster of picture.
Help meeeeeee
  • Thomas F. Schneider May 11, 2010
     were whit awful raster of picture.????????????????????????????
  • 4,041 Answers
Ok there
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Posted on Jan 25, 2010
My printer is skipping lines. do I need to clean something?
1. Make sure that the machine is turned on, open the Paper Output Tray, and extend the Output Tray Extension.
2. Load a sheet of A4 or Letter-sized plain paper in the Cassette.
4. Start Print Head Deep Cleaning.
(1) Press the Menu button.
(2) Press the or button to select Settings, then press the OK button.
The Settings screen is displayed.
(3) Press the or button to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
(4) Press the or button to select Deep cleaning and then press the OK button.
The confirmation screen is displayed.
(5) Press the or button to select Yes and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep Cleaning finishes. This takes about 1 minute 30 seconds.
5. Check the condition of the Print Head.
(1) Print the nozzle check pattern to check the print head condition.
(2) If the print head nozzles are still not clean, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
Jul 01, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Hi all. i am getting thirteen flashes on my printer,not printing at all. heeeeeelp. regards jay ps its a pixma ip 4000
6B00 is Paper feed position error. Look for any pieces of paper in sheet feeder. Clearing this should help you.
Sometimes it
May 23, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I cant start even deep cleanining. Before that more than 50 printed sheets (A4 Matte coated Inkjet paper ) were whit awful raster of picture. Help meeeeeee
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | OEM Systems PIXMA iP3300 Photo Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Photo printing
hi doug
I had to reread your first post the mention of what to do with all the photo paper. I see you mean that you don't use matte photo paper you use matte heavy weight paper. I guess I mean that as a question! That is the only thing that works for me with no smearing problems. I haven't found one that is thick enough for a good feel. I used an avery matte paper that has a coating for photo but it just feels very light. Doesn't smear and looks sharp but very light weight. What brand do you use ?
post in me back
oke, thanks
cropp
Mar 11, 2008 | HP Photosmart 7450 InkJet Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Nov 24, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Paper Jam with no Jam
You may have overloaded your paper feeder with heavy card stock and caused a very tiny jam that you have not found yet so that it will act oddly as it is. Look right up inside unit with a torch and down back where the paper goes in.Try printing on plain a4 agian, place a small stack in feeder, reset paper guides too. Also could be your paper sensor, fixable under warranty.
Aug 12, 2007 | Epson Stylus Photo R220 InkJet Printer
OEM Systems PIXMA iP3300 Photo Printer Logo
2,095 people viewed this question
Top OEM Systems Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
Pamela Leach
Pamela Leach
Are you an OEM Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
