I am getting an error code HD521-2W that won't allow me to reload
I am getting error HD521-2W that won't allow me to load destop configuration.
  • Anonymous Mar 12, 2009
    my computer guy said that I had a virus and that he's going to clean it up and my computer should be fine. Does that even sound right? Could a virus give the impression that the hard drive was failing but really it's ok?
    Novelist:
    Scholar:
  • 72 Answers
Portil,
That error message means is your hard drive is failing or has completely failed.
I doubt you will be able to boot to it, but you can try pressing function key F8 just before Windows starts trying to load and select Safe mode or you can also try from the same menu, Last Known Good.
If you can not get that far and you have valuable data you need to recover, save the old drive and install (or have installed) a replacement drive and install the O/S on the new drive. Once that is working, add the old drive back in as a slave and with a little luck, you may be able to back up some of your data.
If your data is extremely valuable (meaning you are willing to pay to get it back) there are services available that will retrieve all the data from your drive.
Let me know if you need more help or advice.
Honest1abe
Posted on Jan 08, 2009
Unable to scan, I keep getting error message.
Samsung ml-2570 mono laser printer not work destop print
Jan 06, 2014 | Lexmark X2600 InkJet Printer
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
Aug 31, 2012 | Computers & Internet
NEED A PC OPTIMIZER PRO RESTER/ LICENSE KEY
Then you need to BUY the software!
You could also reload your machine clean once very 6 to 12 months ... keeping logs of those programs you *want* to keep ..
thus when you wipe and reload, you will only load those applications you want to have.. and not have tried fifty different apps leaving garbage behind on your machine ...
You could also build a backup of your system inbetween these rebuilds .... so that you can re-load to a known configuration and build upon it.
These "optimizers" are only a temporary measure.. their only *real* power is when they are installed from a CLEAN running state, so that *they* can track changes made to the system and wipe out the garbage..
and lastly ... don't play with garbage, and you won't need a cleaner / optimizer.
Jul 28, 2012 | ASUS Computer International Asus Eee Pc...
RealWorld Cursor Editer When I save custom colors in Swatches, certain colors won't allow the saved file to load. I get an error code 0x80004005. Any way to fix this? It's a real pain to have to...
Try opening the saved file in Notepad. Maybe the problem would be obvious. Otherwise, if you paste the content of the file here as text, I could have a look.
Sep 10, 2011 | RealWorld Graphics RealWorld Cursor Editor
Pxe-e63 error code. No cd disk drive, no back up! Any way to fix?
Try removing the Ethernet cable that is connected to computer. See if this allows it to go thru. If not then the Ethernet card could be bad. You can remove the Ethernet card from computer and reload computer it should load up fine.
Nov 11, 2010 | Computers & Internet
I have startup problem with my Toshiba A205-S4587 laptop. It shutdown after half loading or more than half loading Toshiba logo screen. No Beeps No led flash.
Have you tried tapping the F8 key when you boot up your laptop to get to the safe mode menu where you can then either select the last known good configuration or load safe mode. If this doesn't work try getting to a dos prompt and run chkdsk /f to check for hard drive errors. If all else fails you could reload the operating system from the original disc but you'll lose all of your files or you could try the recovery discs that came with the laptop but sometimes that results in the same thing. There are other options such as ultimatebootcd or taking the drive out and putting it into a USB HDD docking station to recover your files before formatting and reloading the o/s. Good luck.
Sep 30, 2010 | Toshiba Computers & Internet
My Compaq Presario SR5601UK running Windows Vista Home Premium locked up today. When trying to reboot it it now freezes on the moving bar that shows on the screen prior to the windows logo and log in...
The error code BI0HD-4 is a hard disk error. You need to delete all partitions on your hard disk and create new ones and format them
This will solve the problem.
Good luck and have a great day!
Feb 07, 2010 | Computers & Internet
I can't sync my Zen Plus w/ WMP
I ended up going into the recovery mode by pressing the play button and power,,, release the play. It displays the option of Reformmatting and or Reloading O/S. When you do this the computer USB didn't recognize the device. I found that if you use the creative zen recovery tool you can depress the devices return button which allows the software to recognize zen. The recovery tool promted firmware load,, load was successful. For some reason the player went dead after that but this morning I disconnected and reloaded songs. I thought this a.m. I was going to be back to square one but apparently I was tired from the struggle.
Dec 13, 2008 | Creative Labs ZEN V Plus MP3 Player
Difficult to Establish Connection
Do one thing at first you configure your dsl and after same configuration in the wireless g,
then configure the laptops to installed the card driver.and destops also where you want to installed
the card.
Jul 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
1,635 people viewed this question
David Payne
David Payne
