Question about Kenmore 62602 Electric Dryer
Dryer does not turn anymore, dried shoes inside
Its a kenmore dryer front loader 70 , cant u guys help
    Novelist:
  • 148 Answers
The belt that turns the drum has broken or come off
you will need to remove the housing and replace the belt or call for service
Good luck
Posted on Jan 07, 2009
I have a Kenmore front loader - when I turn the knob to start the dryer, it make a noise like it wants to start but doesn't. I have tried to move the knob which indicates what drying time you want to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2011 | Dryers
Hello, my kenmore dryer just stop working, light inside is still on but will not turn or come on Mod# 110.c66492500
Is the door completely shut? Did it stop working right in the middle of a cycle? Are you drying shoes in this load? I'd turn it off, and try it again. If this doesn't work, try it on another drying cycle. If this doesn't work, feel free to contact me again. I hope this works for you. Good Luck! Jim
Mar 30, 2010 | Kenmore Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
I have a Kenmore dryer, my son put his BIG basketball shoes in to dry and now the dryer runs, has heat and does not spin? Can this be fixed or do I need a new dryer?
I WOULD START BY CHECKING THE BELT. THE IMPACT OF THOSE SHOES MAY HAVE BEEN ENOUGH OF A JOLT TO CAUSE THE BELT TO COME OFF THE PULLEY OR BREAK.
Jan 26, 2009 | Kenmore 45081 Front Load Washer / Dryer
Dryer wont start anymore
If the drum won't rotate, you may have a broken belt. I had a Kenmore and as I recall, you have to pull up the top section to see inside. Good luck.
Sep 14, 2008 | Dryers
Kenmore Dryer
Your thermostat could have problem and it confused the temporature inside the dryer. You should change the thermostat. To make sure you can use VOM (vol-amp-milimeter) device to check it. If it reads 0, it means OK. If it reads another number, it is faulty and need changing a new one.
Good Luck
Aug 14, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 Series Electric Dryer Won't Dry.
Your house dryer vent is clogged. There may also be lint in the internal ducts of the dryer.
Nov 26, 2007 | Dryers
Kenmore 62602 Electric Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
