Question about Sharp 27H-S60 TV
Tv wont turn on keeps blowing fuze when powering up
I inspected the board and found a fuze out but when i replaced it. and powered up. it blew. any ideas
Apply ohms law HE HE. TRY THESE V= IR I= E/R just try. i think you have to analys system resistance on that particular circuit. since the fuse blew he he that is short circuit. when current starts to flow and that when the fuse cannot bear so...thats it..bye
Posted on Jan 16, 2009
  • joncsar Jan 16, 2009
    or if you can, you can replace the Power IC if ever my previous suggestions wont work. ok
  • 65 Answers
The voltage tapping is set too low for the voltage you got at home. Make sure that you check.
Posted on Jan 08, 2009
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
My lg 37lh20 model wont turn back on.It cut off when circuit breaker blew a fuse.
Sounds like a power surge hit your TV. Typically when this happens capacitors on the power board with blow. You can buy a repair kit for this problem from several of the dot coms out there. The best one I have found has been tvrepairkits .com. Hope this helps.
Nov 11, 2011 | LG 37LH20 37 in. LCD HDTV
I have a 2006 Hitachi Plasma 42HDS69 that will not turn on. When you power up the TV, the fuse blew. Replaced fuse, powered up the TV, could hear relay click in and fuse blew at the same time. Is this...
You have defective power supply board, Are you OK to strip it down and inspect the board? You will either have to replace the board or have it replaced/repaired professionally.
I hope I have been of help
Feb 14, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
The fuse in my polaroid tv blew. It keeps blowing the fuse when a new one is put in.
The odds are the circuit board that your putting the fuse in is shorted out. I'm guessing that it's a power supply board.
Disconnect every set of wires going to the board. Put the new fuse in. Plug in the power supply board. If the fuse pops, then the power supply board is the problem and has a short somewhere. Most replacement board can be found at a good price at or Just make sure the part number on the board matches up.
Nov 10, 2009 | Televison & Video
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Sony Triniton Fuse Blows
You will have to trouble shoot the board down to the component level I'm afraid. I would for sure pull out the transistors or the FETs to get a good reading on the parts.
Feb 10, 2008 | Televison & Video
Televison & Video Logo
109 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
