Question about Mitsubishi VS-60607 TV
Horizontal lines running on screen
Mitsubishi VS-60607 yr 2001 Audio ok, Just alot of horizontal lines running through screen. I'm a maintenance person but don't know where to start.
    Problem Solver:
  • 7 Answers
There are some transistors attached to heatsinks (small heatsinks) on the left portion of the chassis. this board that has the input board attached to it is the signal board. those transistors are regulators they are labled 7809 or 7805 depeding if they are 9 or 5 volt regulators. use a multimeter to determine if one pin has 9v (or 5v) coming from it. if not this is your problem. i see alot 9v regulators going bad, some take the cap attached to the 3rd leg with it so check that too. if this sounds overwhelming it might be a job for a repair tech.
Posted on Feb 05, 2009
Horizontal/vertical hold is off, picture is moving fom left to right Mitsubishi big screen vs-60607
You better take this fellow to a doctor. You have a stamp size IC with about 250 pins that is bad. Only a tech can replace this or reinstall a remanufactured board into this TV. You may ask the tech to use a freeze spray to find this IC first and then he wil decide how to operate!l
Jan 24, 2010 | Mitsubishi VS-60607 TV
I have a mitsubishi vs-60607. The outer screen was damaged during transport.. First, does the outer screen have a name or part number?Second can it still be purchased?
gona be hard
try the old white tooth paste trick
abit of soft scotch/rag with white toothpaste - scrub easly
should get it better
Dec 29, 2009 | Mitsubishi VS-60607 TV
I need a schematic for a mitssubishi VS-60607 convergence circuit
send me yr email and I can send ya a schematic I have.
larry@riotgun.com
Feb 28, 2009 | Mitsubishi VS-60607 TV
My vs-60607 has waving lines
postive 9v regulator on the signal board and possible capacitor right next to it. the regulator is generic 7809. if you test the output it will be 6 or 7v needs to be 9. when the lines go away it is warm and will read 9v. so do the test cold. i'm assuming you know how to use a multimeter. if not then a local repair shop can do this for you.
Jan 01, 2009 | Mitsubishi VS-60607 TV
Does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
Dec 12, 2008 | Mitsubishi VS-60607 TV
Lines across the screen
we just picked upi a VS-60607 60 inch projectoin tv,  There are several issues with this television.  when powered on the colors are allconstrued and teh image is often chopped and warped, we hooked upi the cable yet there are only two local channels recieved and the power will turn off randomly every severl minutes.   Any thooughts?
Jul 07, 2008 | Mitsubishi VS-60607 TV
Continuous rolling screen.
check out ctechnicians.com and find the error code
Dec 24, 2007 | Mitsubishi VS-60607 TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
272 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
