Question about HP Pavilion dv4000 Notebook
Hp dv4000 screen problem
I have and hp dv4000 , lately when im working on my pc i get a blank screen out of nowhere each time with different color , the pc is still running while the blank screen comes up , i just close the screen and re-open it and everything is back to normal , but 2day i got this problem 4-5 times in 2 hours and its really annoying
hope i can find a solution
thanks in advance
  • 3 more comments
  • badboy0_lb Jan 07, 2009
    well thanks man for ur fast reply
    first of i put the standby setting as never, when im working on the pc suddenly i get the blank screen some times white,gray,green, each time a color but the pc is still turned on , like im chatting on msn , when i get the blank screen i can still here the voice if some1 talked to me and i can even write without seeing anything on the screen , as i said i close the lid and then open it ...
    uddenly i get the blank screen some times white,gray,green, each time a color but the pc is still turned on , like im chatting on msn , when i get the blank screen i can still heare the voice if some1 talked to me and i can even write without seeing anything on the screen , as i said i close the lid and then open it ...
  • Anonymous Mar 04, 2009
    when I am working on my HP pavillion dv 5000 the screen goes black. The computer is still on, so i press the lid close button and the screen comes back on for 5-10 seconds and then goes black again. The only way to use my HP is to constantly press the lid close button. Obviously, this is super annoying. Its not the power settings... I've played with every setting available and still encounter the same thing. Could it be the graphics card or lid close latch malfunctioning??
  • ckbrmc Mar 07, 2009
    I have an HP dv48000 that has been repaired three times in the last six months. The problem remains...
    I am going to buy a mac tomorrow!@
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
  • 186 Answers
With all the descriptions listed above, I see that the issue is with the Lid Switch which should be the faulty component.
If you are getting the display back after the Lid Switch is pressed, this makes it clear that the issue is with the Lid Switch which need to be looked at and fixed.
Hope this helps...
Posted on Mar 09, 2009
    Master:
  • 474 Answers
Sounds like its trying to go into sleep mode or standby or just turning the screen off.
This usualy happens because in the power options, the screen is set to shut off after say 5 minutes. It could be that the lid closed sensor is bad and it thinks your closing it and does this.
Try right clicking on the desktop, select properties, in the pop up box, select the scren savers Tab and at the bottom it should have a button for the power options.
Click that, in there you should see several new tabs partaining to your power options. one has some drop down boxes that lets you set what it does when the lid is close, when you press the power button and when you press the sleep button.
I would try turning the, " turn off screen option" to off and see if it still does it.
It usually says. 'When I close the lid to my laptop, i want it to: " then it will list the options.
Also turn off the standby settings if you want so it doesnt go into standby every time you walk away for 5 minutes.
Just set it how you want. but for now, just disable the close lid options so we can see if it still does it.
Good luck and let me know.
Posted on Jan 07, 2009
  • Chris Busch
    Chris Busch Jan 08, 2009
    Well, it sounds like the graphics processor is going out. If thats the case, then you may be out of luck cuz you have to replace the whole Mobo.
    Its not over heating or anything is it?
    Try updating the drivers through the manufacturers web site for you laptop/notebook. It could just be that.
Push down on the plastic left hand palmrest. If the display returns then you have a factory design flaw that HP will not warranty.
Posted on May 06, 2009
Black screen hp pavilion dv4000
not sure on this for sure but it sounds like what the dv6000 did or does and the motherboard needs replaced.
Sep 12, 2013 | HP Pavilion dv4000 Notebook
Powers on but has blank screen
Remove all media, DVD,CD,USB, Unplug, remove battery, plug in, reboot, Is the fan spinning? LED's blink? Sound? At reboot do you get a BIOS screen? Does the blank screen have a white cursor in the top left? Need more info.
Mar 02, 2013 | HP Pavilion dv4000 Notebook
Hp 99dv30us, screen is blank
Common issue you will have to reflow the GPU or replace the motherboard. Check out www.msbin.com for a diy guide.
May 14, 2010 | HP Pavilion dv4000 Notebook
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
HP DV4000 laptop turns on and off without loading
i think it's the power ac inside ur motherboard ,u have to change it ,and u can try to install a fresh copy of windows before that.
Nov 13, 2009 | HP Pavilion dv4000 Notebook
When i on the hp pavilion dv4000 it is just blank screen and does not boot at all.
go to safe mode by press F8
start>run>type "msconfig"
select service tab
remove all tick mark
apply
ok
restart
Oct 29, 2009 | HP Pavilion dv4000 Notebook
TouchPad NOT working at all
yes. there is a high probability that the problem is hardware. try different versions of synaptics, not necessarily from toshiba
Oct 08, 2009 | HP Pavilion dv4000 Notebook
DV4000 display is in XGA mode does not fill the screen
Please check the unit with the external monitor>If the External monitor works fine >Its an issue with the LCD of the unit you can replace it
If the External monitor is also actining in the same way>It could be an issue with the system board.
After all the driver updates this is the finall step,
If not possibel to replace the LCD, try to reinstall the OS
Jul 03, 2009 | HP Pavilion dv4000 Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
865 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
