Question about Actiontec (GS503AD3-01) Modem
My actiontec verizon dsl wireless modem/router loses it's connect
I lose my connection a couple times a day for maybe 30 seconds. do i need to download the updated drivers?? i have checked everything.
  • 45 Answers
Http://www.actiontec.com/support/index.php
Select the model and then download the firmware. Instructions are also included but may vary depending on model.
Posted on Jan 07, 2009
Trying to connect my router to Centurylink, I have a solid DSL light and my connection status shows a speed. PPP connection is stuck on connecting. I am trying to determine whether this is due to my...
You need to verify your connection type w/ Centurylink- they may run on DHCP which is a different connection protocol than PPPoE. If you have a static IP address, fair warning: the Verizon Actiontec is historically tetchy on static and NOT to be used as a primary modem/router- it will lose settings.
Sep 19, 2010 | Actiontec GT704WG Wireless Router...
It appears to be over heating and goes down after 30 minutes or so and then we have to turn it off and on again as it loses the connection to our wireless computers in the house. Doesn't happen to the...
You can run into that problem if the router is from verizon or whoever and you are using it with another dsl provider. contact your provider about how to set up. or update firmware.
Jan 02, 2010 | Actiontec (GT704WG) Router
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Nonexistant customer service by Actiontec
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
Mar 27, 2009 | Actiontec GT704WG Wireless Router...
Verizon GT704WG DSL Modem wants me to install software
If my memory serves me, I didn't install the software for my Actiontec modem/router combo. I call Verizon and told them I refused to install the software and they helped step me through getting rid of this garbage. You should never have to install software to get a modem or router to work as any software the comes with it, is simply used to provide easier configuration.
Since I couldn't find anything about bypassing this software, I would suggest contacting Verizon directly. Their technical support should be able to assist you.
Mar 09, 2009 | Actiontec GT704WG Wireless Router...
Verizon DSL, keep losing signal, 2 different routers, same issue
try upgrading your verizonservase to the power pake one they might have a better router for you wich is the 29.95 on for high speed internet servas
Jan 04, 2009 | Actiontec GT704WG Wireless Router...
Frustrated beyond belief
Update the firmware:
Follow the instructions carefully:
http://www.actiontec.com/support/product_details.php?pid=92&typ=all
http://www.actiontec.com/support/index.php
Please remember to rate all users who assist you for free :)
Aug 26, 2008 | Actiontec GT704WG Wireless Router...
Constant intermittent loss of connectivity, even with new gt704wg router
It might be that you have a voltage drop. I noticed that this modem is very sensitive to voltage 'dips' and it will 'reset' itself if even the slightest dip in power hits it.
I have a A/C that sucks power when it cycles and every time it does I lose the internet connection. So I set up a 12 volt battery with an DC to AC inverter and run the modem off of battery power.
That might be the problem your having.
Actiontec (GS503AD3-01) Modem Logo
665 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
