Question about Plantronics Discovery 925 Bluetooth Headset
I need the code to pair myPlantronics Discovery 925 Bluetooth Headset to my blackberry storm. can u help me?????
  • Anonymous Mar 02, 2009
    Can't get it to pair on a regular basis, then randomly it will pair without asking for the code, a few weeks later (having forgotten the whole pairing-issue) I tell it to disconnect to save my phones battery life for whatever reason....once it pairs never drop!
The code should be f-u-c-k_y-o-u
Posted on Jan 08, 2009
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Good luck from Headsets Direct!
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
I was using my plantronics 99xx with my blackberry and it was working fine but now the headset doesn't work anymore even though the blackberry has the plantronics see in the bluetooth list
What you need to do is eliminate the headset from your Blackberry and re-pair the two devices. The link below has the pairing instructions. They're the same for the Discovery 925.
http://www.plantronics.com/us/media/media-resources/literature/user_guides/discovery975_user_guide_en.pdf?WT.dl=20
Aug 25, 2011 | Radio Communications
Plantronics 925 connects to my Blackberry Bold but disconnects within 2 seconds
Looks like there is a battle between two or more equipment items.
Are you using more bluetooth equipment on your Blackberry?
Then delete them from your phone. And try pairing again with the 925.
Then activate the option for automatic connecting with the 925.
After this you can connect the other bluetooth equipment but do not set either of them on automatic connection.
Hope this will work.
Aug 02, 2011 | Plantronics Discovery 925 Bluetooth...
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Blackberry strom 9530 cannot search bluetooth headphones... problem with Plantronics Discovery 925
    Be sure the the headset in in 'Pairing' mode.
    When in pairing mode, the light should be flashing red and blue or have a steady blue
    Oct 18, 2009 | Motorola Mobility H375 Bluetooth Headset
    Switching on discovery 925
    Switch the bluetooth function on your phone, search for devices and then pair with your headset once it finds it. Allow it to connect without confirmation and leave your bluetooth switched on on your phone. Everytime you turn on your headset it should connect automatically.
    Apr 10, 2009 | Plantronics Discovery 925 Bluetooth...
    I need to know how to pair my plantronics discovery 925 - I have no user instructions
    set your phone to discovery mode. press and hold the button inside of the diamond until it flashes blue and red. once you do that, your phone should see it. Pair it to your phone by putting in code. 0000.
    Happy Calling :)
    Dec 19, 2008 | Plantronics Discovery 925 Bluetooth...
    Plantronics Discovery 925 Bluetooth Headset Logo
    191 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
