Question about Printronix LaserLine L1524 Printer
Won't print in landscape mode
We have a Printronix Printer L1524. We are trying to print PDF file in landscape mode to make it print properly - but it is a portrait mode document (so it should print sideways, still be in portrait mode but sideways thereby fitting on the paper. We tried to change print settings to landscape more, but the printer still prints in portrait mode going and not fitting on the paper.
  • 5 more comments
  • Alla Bespalov May 30, 2007
    Here's more information: we are sending Adobe PDFs generated from an Oracle 9i Reports Server running on Solaris 8 to a Printronix L7032 continuous form printer being managed by IBM Infoprint Manager for Windows.
    (Sorry I made a mistake on the printer, it is L7032, not L1524)
  • Alla Bespalov Jun 02, 2007
    We aren't printing from Adobe, but from Oracle Reports and it is getting automatically generated so it's very hard to play with the settings. We'll try your suggestions when we troubleshoot using Adobe, but still need a solution for it to print from Oracle reports. Thanks for trying!
  • Anonymous Mar 14, 2014
    canon ir 3035 is printing portrait as lamdscape. Where can I change this settings ?
  • Anonymous Mar 26, 2014
    printing landscape instead of portrait
    gestetner ricoh MP3010 sends all facsimiles in landscape not portrait and reduces the text size considerably. Cant find settings to adjust this anywhere! Stuck with this issue for years now and recipents tend to complain about this.
  • Anonymous Mar 29, 2014
    I am trying to print a portrait document, but when it comes out of the printer, it has been printed sideways, and half the document is cut off. The setting say portrait, though. I don't know where the problem is!
  • 883 Answers
At the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Posted on May 31, 2007
Can the Printronix P7005 PSA3 print PDF files?
Sounds like your printer may need IPDS, I'll need to see a configuration page from your printer in order to determine whats on it. you can email me it at rcardenas@mrp.to
Apr 09, 2013 | Printronix LineJet® P7005 Printer
Landscape printing on t2340
printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Jan 23, 2013 | Tally T2340/24 Matrix Printer
I LOST MY CD DRIVER FOR PRINTRONIX P5205B WHERE CAN I DOWNLOAD
I tried some of the online drivers. They were not good for use with vista. The P7000 driver seems to work for my P5205b...except that .pdf files print up and down instead of sideways!
Oct 13, 2010 | Printronix P5205B Matrix Printer
Printronix L1524 is printing very faded labels. OPC Drum is brand new. Everything looks good, in my opinion. I believe it it is the wire below the OPC Drum and the label that is the culprit. any help?
This can be caused by a worn corona transfer wire. It can also be caused by the follow;
Developer starter toner is weak, change developer.
Laser Sight Glass is dirty, Clean, it is located under the top of the printer.
Transfer unit, bad, or poor grounding.
for more info, call BNL 562-688-2373
Dec 24, 2009 | Printronix LaserLine L1524 Printer
Our L1524 passes the diagnostics tests when we turn it on but gets stuck "Loading Fonts" with a 8344 Failed error. Ideas/Solutions?
Remove the controller boad in the back. You will see 4 SIMM'S, remove, and reset them. if this does not solve your problem, call BNL 562-688-2373 for free tech support. Ben
Nov 13, 2009 | Printronix LaserLine L1524 Printer
P5010 line printer, I want to print in condensed mode
This can be done by sending an "escape sequence" to the printer. Basically you create a text file using Notepad and then print it. Of course the magic escape codes to do this are found in your P5010 Owners / Users Manual. I don't have a copy at hand. If yours has been misplaced, you're pretty much out of luck. As a long shot you can try the standard Epson codes for condensed print.
Jan 01, 2009 | Printronix P5010 Matrix Printer
I have problem with Printronix showing error 25 Encoder fail
Call a technician. This is the resolution in my manual for the problem: "Defective or dirty encoder needs to be replaced. Call a technician."
Sorry! This thing has some sensors that do go bad on occasion.
Dec 05, 2008 | Printronix LaserLine L1524 Printer
25 Encoder fail
1. The tractor encoder signal is faulty.
a. Clean any toner or paper dust out of the encoder sensor.
b. Inspect the tractor encoder wheel for damage. Replace it if necessary.
c. The encoder sensor is faulty. Replace the tractor encoder board or the entire tractor
unit.
d. The fuser drive clutch is slipping; replace it.
e. Replace the Engine Controller Board.
f. Replace the encoder cable.
�� Tractor Encoder. The Tractor Encoder Board has two optical sensors that sense the
1/8 inch and 1/16 inch slots in the Encoder Wheels. These pulses are sent to the Engine
Controller Board and are used to monitor and control print location and paper movement.
Location
Remove the Tractor Encoder Cover by removing 1 Screw.
NOTE: Upon installation, the groove on the bottom of the Encoder Cover should
straddle the top of the left end of the Tractor Frame.
Left side of printer, just left of the tractor assy.
Print problems
Its probally the way your configuring the way the print file is printing (IE: portrait or landscape) portrait is the top side being 8.5" or landscape being 11" wide on top! First make sure your printer has both landscape and portrait formats loaded into your printer. This will help the you by when you go to print you can try both trays to print to. If this is not your problem then its the way driver is configured and possibly try printing to a pdf file. If you cannot create a PDF from the application try finding some trial software that will enable you to create PDF files. If you can create a good PDF file and can then print that file to your printer you will have better results, because the software your using might not be configured to work with this printer. PDF files will work great and you can see the preview before you print. If you have more info like what exact software you are using and what platform(PC or mac) and repost this question i will get the update and i can answer this question better.
Aug 10, 2007 | Canon CLC 1150 Color Copier
Printronix LaserLine L1524 Printer Logo
2,412 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
