Question about HP Photosmart 2575 All-In-One InkJet Printer
I have an hp Photosmart 2575 All in one printer. It has not been printing and I found that the IP address is not saving n my printer. I went to Network, Advanced settings and then IP address. If I enter the numbers for the address and then ok to save it doesn't save. What can I do?
  • 45 Answers
Found this in its manual:
When manually entering an IP Setting, you must already be connected
to an active Network, otherwise the setting will not stay when you exit from the
menu.
http://h10032.www1.hp.com/ctg/Manual/c00485365.pdf
Posted on Jan 07, 2009
Hp photosmart 2575-in-one printer scanner pdf files save
Try visiting this site: h30434.www.hp.com type that into your address bar. It is all about HP 2575 scanner pdf files that won't save
Jun 16, 2014 | HP Photosmart 2575 All-In-One Printer,...
Ip address change
Press "Menu"
Scroll to "IO sub menu" Enter
Scroll to "TCP/IP" Enter
Scroll to "Manual settings" Enter
You can see the saved IP address, it can be change, enter desire IP address...enter for save the changes....back to main menu..
To confirm: (You can follow the above said method to see the saved IP) OR
Press "Menu"
Scroll to "Information menu" Enter
Scroll to "Print menu map" Enter
Printer prints menu map, you cam see the entered IP address here, if you found its success, if not try once again..
May 12, 2014 | HP Laserjet P4515x Printer
Uninstalled printer and reinstalled with a network cable option and printer shows up as offline. I just bought a new computer and set the printer up the same way on it and its fine, did same thing on old...
check the ip address for the printer print a network config page from the printer itself, then the same ip on the ie u will get an ews page there u need to manually fid in your network info & it shud be working
Mar 30, 2010 | HP Photosmart 2575 All-In-One Printer,...
How to get free download for a hp 2575 photosmart manual frank
Hello there
Here is some information below that will help you get the manual ok?
I hope that this is very helpful
best regards michael
HP Photosmart 2575 Manuals, Support and Troubleshooting ... Free download of HP Photosmart 2575 User Manual. Troubleshooting help from
experts and users. Ask our large community for support. http://www.retrevo.com/support/HP-2575-Multifunction-Printer... - 107k - Similar pages HP Photosmart 2575 review - Multifunction Printers Quick links to useful Expert Reviews for HP Photosmart 2575 describing pros and
cons. User sentiment in Forums. Download to User Guide and Manual. http://www.retrevo.com/s/HP-2575-Multifunction-Printers-revi... - 85k - Similar pages
Nov 16, 2009 | HP Photosmart 2575 All-In-One InkJet...
Unable to print or scan with HP Photosmart 2575 to new Vista
That means that the printer software installation is corrupted.
You need to reinstall the drivers for this printer.
If you have original printer disk, use the disk to reinstall the printer.
If you have misplaced the disk, then you can download driver from link below:
HP Photosmart 2575 All-in-One Printer
Run installer file after download has finished.
Start driver installation with printer USNB unplugged, the printer setup wizard will tell you when to connect the printer to computer.
Set the printer as default when asked.
Feb 17, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
HP PhotoSmart 2575
hmmm..sounds like a new set of drivers might be just the thing.
get em here
Mar 05, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP C6100 Wireless printer has stopped working
The HP C6100 series has had some ip setting issues. One day my printer didn't print. I checked the ip settings on the printer and got some 648.154.1.654 address. I had no clue where this ip number came from, because my router's ip is 192.168.0.1. I went into the settings of my printer and set my ip settings manual. Then I went into the router settings and reserved the ip setting I previously setting on the printer to the printers MAC address. I also set static ip address for each computer on my network. This network response issue started about one year after I purchased the printer. I still lose connection every once in a while, but rebooting the router reconnects the printer and everything sitting in the que to print starts to print. To stablize the issue: upgrade router firmware, set static ip address on your network devices, reserve those ip address in your router, , if all else fails reboot router.
Jan 23, 2008 | HP Photosmart C6100 All-In-One Printer
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
157 people viewed this question
Ben Johnson
