Question about Sony KP-48S75 48" Rear Projection Television
Sony kp-48s75, shadow or ghosting picture
I have a Sony kp-48S75 that has just started shadowing or ghosting picture. Any idea what the problem or replacement part might be?
  • Sony Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneersony kp-48s75, shadow or ghosting picture - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
My mitshibitchi 1080hd has double vision with green and pink working perfect then all of a sudden
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Mar 21, 2011 | Sony KP-48S75 48" Rear Projection...
Flash focus can no longer line up all colors,and gren is the one always sticking out;do I need to replace all my "color lamps"?
No,this tv have no projection lamp,tv only have 3 CRTS tubes guns R,G,B.Ur tv have a problems known convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike.The tv convergence board is dead.Tv convergence board,must be replace 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 17, 2011 | Sony KP-48S75 48" Rear Projection...
We have a Sony KP-48S75 48 rear projection television The picture has colors of blue, green, and red around the figures on the screen. what is wrong. Can this part be replaced without going to a...
Its convergence ICs, the STKs gone bad. The repair can be done only by person who knows about PCBs with embedded components. and good with soldering. You can down load the service manual for your tv from this fixya site tech support and decide how you would like to do it. You can check for costs and more FAQs on www.fixurtvs.com. If you are not sure best bet is to go for professional repair. Thanks if you took time to vote for me.
Mar 21, 2010 | Sony KP-48S75 48" Rear Projection...
Broken the plate( F and L )difussion
Here are part numbers of plate diffusion of Sony KP-48S75 TV
4-070-280-11 PLATE (L), DIFFUSION
4-058-455-11 PLATE (F), DIFFUSION
Oct 24, 2008 | Sony KP-48S75 48" Rear Projection...
G board
Here is required details...
G board is Power Supply and Horizontal / Vertical Out board and part number is ...
" A-1316-471-A " G BOARD, COMPLETE
Its available in Tri-State Module Inc and price is approx $200
Oct 13, 2008 | Sony KP-48S75 48" Rear Projection...
G-board fir KP-48S75
I been replied you in your post, check it out..
http://www.fixya.com/support/t1129194-g_board
Oct 11, 2008 | Sony KP-48S75 48" Rear Projection...
Kp-48s75 sony rear projection
does a red LED ever blink on the front panel. if you ever get 5 blinks than you are most likely haveing CRT failure the IK lines arent right and it is blanking the video.
Feb 19, 2008 | Sony KP-48S75 48" Rear Projection...
Pink in picture and green ghosting on live program with live people in picture
yes sounds like all 3 tubes are going bad. they are prolly not available anymore. try to adjust the settings in the menu. adjust PICTURE as low as possible and boost the BRIGHTNESS this might help but fixing this tv would not be cost effective.
Oct 17, 2007 | Sony KP-48S75 48" Rear Projection...
Green haze/shadowing on left third of tv
SOUNDS LIKE YOR GREEN CRT NEEDS TO BE REPLACED OR PERHAPS A SMOOTHING CAPACITOR ON YOUR 200V LINE IS OPEN CIRCUIT,PERHAPS YOUR CONVERGENCE ADJUSTMENTS NEED TO BE RESET.
Aug 11, 2007 | Sony KP-48S75 48" Rear Projection...
My tv is broken
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Try the suggestions on this post from the Troubleshooting page: http://www.fixya.com/problems-solutions/t101379,p228476/Sony-KP-48S75-48-in-Rear-Projection-Television.aspx
Jun 18, 2006 | Sony KP-48S75 48" Rear Projection...
Sony KP-48S75 48" Rear Projection Television Logo
138 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
