Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Lower level format problem
I was trying to make the memory storage on my pictures smaller, so i went to Format, then checked Lower Level format for the memory card and hit ok. After that, I couldn't view any of the pictures I had on there before. PLEASE HELP!!!! the pictures i had on there are for work! They are irreplacable.
  • Sarah Montoya May 31, 2007
    Thank you for your response, i did'nt think anyone would reply... Anyways, i did look into data recovery, and wow it costs ALOT.. Too much actually, so i looked online to find maybe a free data recovery i can run on my own computer, but it downloaded and no luck at all, nothing was retrieved. Live and learn I guess. This is really horrible but i dont think there is much left to do now, there gone.
  • 32 Answers
Unfortunately, there is little you can do since low level formatting just as same as formatting a hard drive on a computer. There is one way that I know of called data recovery/forensics but this service is extremely expensive. A forensic program called "EnCase" will read any data on the card but the data may be corrupted to the point where there won't be anything of use.
Posted on May 31, 2007
SOURCE:
Why will my memory card not format
Remove it from camera, install it in a USB Memory Card Reader. If your computer recognizes it, format it.
If won't accept format, try installing a low level format tool, like HDD LLF Low Level Format Tool
http://hddguru.com/software/HDD-LLF-Low-Level-Format-Tool/
Be carful and DON'T format by mistake hour Hard Drive
If still can't format it, it went bad, buy a new one
Apr 25, 2015 | Cameras
A write protect
Or check the Lock switch on the card is in the up position, like the one on the picture on the left.
This is how the switch should be.
No switch on the card is the same as locked.
Be aware you can format a card in a computer or even in another camera. Before you start using the card in your camera, use the format option in your own camera. Some camera's won't work if the card is not formatted in the own body.
Apr 16, 2015 | Cameras
I cant take a picture on my aqua wp 5300 i went through the formating process on the sd card but it still says that the card is full and want let me take the picture?
SD cards are external storage devices used with small electronics, such as cell phones, digital cameras and camcorders. There are two compatible file systems you can format your SD memory card with: FAT16 and FAT32. FAT16 is the most common and is used with cards that are typically smaller than 2GB.
Apr 08, 2012 | Cameras
How cani unlock my camera? i cant delete my pictures?
Erasing a memory card: when erasing a memory card, individual photos are deleted from their directories on the card. You can erase one or more user selected images at a time, or erase all images at one time. However, any images that you've selected to be "protected" through another menu option will not be removed during the erasure process.
Formatting a memory card: format a memory card sample menuFormatting, on the other hand, deletes all images from a memory card, even the ones that may have been protected. It recreates the file system including new directories and folders where images are saved on the card.
Unlike erasing, formatting improves the overall performance of a card.
Low level formatting: some digital cameras offer a low level format in addition to the standard format option. With a low level format, all data on the card is deleted. New directories and folders are also recreated during this process.
A low-level format of a high speed memory card helps ensure smooth continuous shooting at a constant interval. For optimal video performance, it's also recommended that a low level format be done sometime prior to recording.
In camera, not computer: though opinions vary, many recommend formatting a memory card in a digital camera, not via a computer. If you plan to use a memory card that was previously used in another camera, format the card in the new camera before taking any shots.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 02, 2011 | GE J1455 Digital Camera
How to unlock my camera,i cant delete pictures
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Lost pictures?
I'm sorry to say that the card is erased. A format is a complete erase of the memory card.
However, your pictures aren't necessarily lost. First of all, make sure you don't use the memory card in the camera. As long as you haven't taken any new pictures on the card, you should be able to recover your pictures.
Next, you will need a USB memory card reader that accepts your type of memory card.
Connect the card reader to the PC, then insert the memory card in the memory card reader. Then download this program: http://www.datarescue.com/photorescue/download.htm
This is a program for recovering lost pictures from formatted memory cards. It's a free trial version, that will show you the photos that can be recovered. To do the actual recovery, you will have to buy the program for $29.
I hope this helps you! Let me know if I can provide more help.
Regards,
/Chris
Jan 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lost of pictures from memori card
The camera does not support low level format, so the pictures may still be on the card.
To _TRY_ to restore your images, get a USB SD-card reader (they are pretty cheap), and try a utility that restores files on memory cards, such as VaioSoft Recovery Manager 1.5
Jan 05, 2008 | Canon PowerShot SD800 IS / IXUS 850 IS...
Short video on High quality
Have you made sure to format the card first?
May 21, 2007 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
111 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
