Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Len error okay this Wat happen i had my camera in my pocket and i quess it turn on but then the len go crammed in my pocket and kno it say len error and the len does not go in the camera Please Help
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 21, 2010
My Kodak easy-share len is stuck. what do this Len error 20e 1,0,0 means?
There are some steps which can be followed which may resolve this problem which as follows,
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
Sep 13, 2014 | Kodak Cameras
I have a lens error
what is the exactly error,does the len stuck and canont step back and forward. maybe your len is in bad condition or the lens bayonet is bad.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Aug 24, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Communication between camera and len error
Its common problem. Its happens when the lens guide pin is damaged or dislocate from the lens guide line. Go for replace that or repair.
Thanks.
Mar 26, 2010 | Canon Cameras
Lens error
change your battteries installl new one
Aug 23, 2009 | Canon IXUS V2 Digital Camera
Lens error 0x04110000 when camera turned on
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 16, 2009 | Pentax Optio 50 Digital Camera
Len won't close , camera won't work
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 17, 2009 | Cameras
Lens Error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 15, 2008 | Kodak EasyShare C763 Digital Camera
Len
camera lens has problem.
need repair lens
mydc digital camera reapir
Jun 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Lens Error
Two posibilities : either the gear box needs attention or the lens itself is impacted . The first problem is not so expensive to sort out by your repair outfit but the impacted lens problem is expensive ( may require replacing lens assy. ). Anyway camera has to go in I am affraid.
Aug 24, 2007 | Kodak EasyShare C643 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
