Need to know what type of printer to buy for my compaq M700 laptop
My system is Windows XP 2002 service pack 2, 256 ram, 447 Mhz. Sorry, I should have put more info for you, dont really know what I'm doing.
Thanks,
April
Re: need to know what type of printer to buy for my...
As long as Windows XP or Vista supports it. Just look for the printer specifications wether it is supported by Windows XP, SP1 then youre good. There are just too many models to list here.
The following are the system requirements for Microsoft Security Essentials
Operating System: Genuine Windows XP Service Pack 3 (SP3); Windows Vista (Gold, Service Pack 1, or Service Pack 2); Windows 7*
For Windows XP, a PC with a CPU clock speed of 500 MHz or higher, and 256 MB RAM or higher.
For Windows Vista and Windows 7, a PC with a CPU clock speed of 1.0 GHz or higher, and 1 GB RAM or higher.
VGA display of 800 × 600 or higher.
200 MB of available hard disk space.
An Internet connection is required for installation and to download the latest virus and spyware definitions for Microsoft Security Essentials.
Internet Browser:
Windows Internet Explorer 6.0 or later.
Mozilla Firefox 2.0 or later.
Microsoft Security Essentials also supports Windows XP Mode in Windows 7. For more information see the system requirements for Windows XP Mode in Windows 7.
Windows 98/2000/Me; 200 MHz Pentium or compatible; 64 MB RAM; Windows XP; 300 MHz Pentium processor or faster 128 MB RAM; Minimum 427 MB hard disk space; 800x600 display, 16-bit color;
Windows compatible mouse; Windows compatible sound card and speakers; Windows compatible printer (monochrome or color); Microsoft Internet Explorer 5.0 or higher
33.6 Kbps modem or faster and Internet service provider account required for Internet access, online graphics, online projects, and animated greetings
Encore/ RiverDeep
PC
This is system requirements "above" Vista and Win 7 are not supported.You would have to contact them for support.Sorry.
Of cource supports but work slower then 2000, After install change theme into Windows Classic, then right click MY Computer> properties>Advanced and change perfomance settings to "Adjast for best perfomance" and it will work normal but if you want xp with visual effects it will slow down and make pauses during work.
Yes you can upgrade the memory but it is a pain. Most modern systems have a little panel on the bottom you can remove to add more memory but to add memory to a M700 you have to remove the keyboard. It will take 2 sticks of 256Mb PC-100 SODIMM memory.
Explanation of "Virtual Memory". RAM is what your processor uses to do it's "thinking". The hard drive is like a filing cabinet, it is for permanent storage. Virtual memory is nothing more than a file on the hard drive. When your computer does not have enough RAM, it writes information to this file and then reads it back when it needs to. This drastically slows down you computer and can cause your hard drive to fail prematurely because it is work harder than it would have to if you have enough RAM.
The M700 has USB ports so any new printer should work as long as it has drivers for your operating system. If you have Windows XP, almost all printers will have drivers for that. If you have a different version of Windows, just as the printer salesperson if it has drivers for your operating system.
As to what type to buy - it depends on what you want to do. Inkjets are cheap to buy but the ink is expensive.
Black and White laser printers are a bit more expensive to buy but the per page cost is a lot lower to print.
If you want to print colour (photographs) go with the inkjet. If you are using this for work or school and need to print a lot of reports, go for the laser.
Note: Don't forget to buy a USB cable, it doesn't come with the printer.
This is Romeet, id like to try and assist you. Please specify for what operating system you would like to download the drivers for? and i am assuming you have an Operating System CD with you already.
Please refer to link below for Operating System Specific System Drivers.Example for windows XP Professional you will need to click on " Windows XP Professional " and so forth.
you may struggle to find 100MHZ ram, but 133MHZ should be backward compatable, if you go to crucial.com, it should give you the alternatives you can fit
http://www.crucial.com/
