Question about Kenmore 98702 Stacked Washer/Dryer
GE front load washer WSXH208A1WW belt slips off
GE front load washer WSXH208A1WW - The old belt was worn and stretched. We replaced the belt but it keeps slipping off. Is there a way to adjust or could something else be wrong?
  • 15,935 Answers
There is a belt tensioner pulley. If it is failed - your belt won't properly tension.
It appears your tensioner has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
How to dissasemble GE model wsxh208a1ww
log on to applianceaid.com/appliance-repair-help. find your make ,model and they will give you step by step instructions on the repair. the site also includes pictures of every detail. good luck ,Steve
Oct 15, 2012 | GE WSXH208A Front Load Washer
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Spin cycle will not work but motor is running. Washer is only 2 yrs old and seldomly used
does agitate cycle work? a. could be water leakage that's causing the belt to slip (if it's not 'direct-drive').
b. motor may need adjusting, because belt has stretched! if you're handy, then you can do it yourself, if not hire someone to check it out! cheaper than a new washer! unless it's water leak- as i try to always caution- UNPLUG IT!!
GOOD LUCK!
Apr 17, 2010 | GE WBSR3140DW Top Load Washer
GE front loader does not go into final fast spin and does not drain.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. It sounds like you may have a slipping (loose or stretched) v-belt. See if you can get the back off and look for a way to tighten the belt. This is a frequent problem. The built in a way to tighten the belt.
Nov 24, 2009 | GE WSXH208A Front Load Washer
Don't spin clothes out very good. at the end of the wash cycle my clothes are still very very wet.
Your drive belt is worn and slipping. You can either try to replace it yourself, or pay a repairman to do it. Those are your options there are no adjustments. Thanks, Dana
Sep 24, 2009 | GE WSXH208A Front Load Washer
How di change the belt on a 2000 maytag top load washer?
HI. you may have a defective idler pulley. excessive bearing clearance can cause the belt to slip off at times. A worn belt will slip off as well. i suggest gaining access to the belt to inspect for damage. you can start by pressing in the middle of the longest straight run. It should deflect no more that one inch. also inspect the belt for cracks, frayed edges or other signs of excessive wear. if any damage or excessive looseness is found, replace asap. It could also be stretched.
((You can check the pulley by removing the belt and physically rotating the pulley, if the pulley has excessive wobbling or shifting, replace it))
Sep 03, 2009 | Zanussi ZWF1430W Front Load Washer
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
Grease on clothes?
This is a 50 year old problem on washers.  All brands.  You just got lucky on this one.
If you buy a new one, consider a unit built by Whirlpool.  They also make Kenmore and others.
Nov 12, 2008 | GE WSXH208A Front Load Washer
Replacing belt on GE front loader wsxh208a1ww
Ron, be sure the wheel the belt goes around is not loose. The belt will come off if it is loose.
Jan 09, 2008 | GE WSXH208A Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
311 people viewed this question
Sal De
fordexpert
Robert Rankin
