Question about Zenith XBS444 System
Zenith XBS444 - Shuts off without warning
Hello I'm faced with the problem as others. The zenith xbs444 system works for 1 to 15 minutes then does the same thing 3 blips and powers down. I've tried everything I could think of.
I've pulled the fan out and checked the board for power, but no power.
Again, there are 3 bleep noises then the TV goes to a blank screen and the system seems to reset it's self, I mean the power kinda of flashes and "power light" goes from green to red, but the clock keeps it's time.
Thank You,
  • davidlentz Jan 08, 2009
    Please tell me where I might find the "battery".
    Thank You,
  • Anonymous Mar 24, 2009
    Where do you get the IC's KIA7805A
  • 3 Answers
I just got done repairing a Zenith XBS444 and the problem is IC706, This defective component is located on the audio output board. Part number is KIA7805A. There are 3 KIA7805A IC's in a row, first one is not on a heat sink, the two behind it are on tall heat sinks, it the 3rd one that is defective. I would advise you to replace both IC's that are on the heat sinks.
Posted on Jan 28, 2009
  • 3 Answers
Battery needs replacing
Posted on Jan 07, 2009
I had the same problem make sure the cooling vents are unobstructed and that the fan is running i had to replace the fan. its a very easy procedure and can be bought at most electronic stores (radio shack)
or parts express for under 12.00
Posted on Apr 16, 2010
Zenith tv rb50m88w shuts off without warning
Most likely there is a bad solder connection or connections somewhere in the set--not likely to be a do it yourself repair unless you have some skill in this area.
Jun 16, 2012 | Zenith Z44SZ80 Television
The system shuts off after a few minutes
It could be overheating, have you checked how warm it is? Is it in the open. Zenith systems seem to have a lot of problems associated with them
Mar 25, 2008 | Zenith XBS444 System
I have a Zenith I played a dvd an it worked fine - put another movie in the dvd player and was going to watch that one and it never read - screen kept saying 'reading'. I tried another dvd and the...
try using a CD cleaner disk..
How old is the system?
DO CDs work when you try them?
Put a disk in... remembering the position it was in..
Then try to play the disk...
Eject if it does not play and look to see if it has moved to a different position...
If not, there is a motor problem or the laser is not sensing the disk being there.
Have you ever opened up the main box of the system?
Has anyone else been inside it?
If yes, then maybe it is time to do it again to observe if there is movement of the laser pickup..
Jun 01, 2011 | Zenith XBS444 250watt DVD/VHS 6-Speaker...
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
Jan 13, 2011 | Zenith XBS444 System
Hi. I'm trying to play a homemade dvd with several slideshows and a selection menu. It works jst fine on my PS3 at home but nothing shows on our son's TV that's connected to a lifestyle 38. Other DVDs...
The dvd may be in the wrong format for your Son's t.v. PS3's play several formats that the lifestyle 38 may not be compatible with. You can download a video converter such as Any Video Converter and format the disc for whatever format you need. Probably mpeg2. Then it should play on most players.
Sep 29, 2009 | Zenith XBS444 System
Same Problem, Speakers Do Not Turn On
If it's still under MFG. Warranty, get it replaced. If not, weigh the cost of repair vs. replacement. What has more than likely happened is the unit has seen either a "Brownout" severe voltage drop then spike to commence power, or a power surge. It's a very common problem with today's electronics of all kinds. It will either have a bad power supply or bad transistors and will range from $ 125.00 - $ 175.00 to repair on avg. When you have it replaced or repaired, make sure you purchase a good line conditioning surge protection unit like Monster, Panamax, or Furman. Not a power strip, that's just a glorified light switch. Sorry for the bad news! Hope this helps
Jun 07, 2009 | Zenith XBS444 System
No audio for tv?
Since not all devices have the same in/outputs available, if you are trying to interconnect them, it helps to know the make and model of both, not just one.
There are several possibilities to connect external devices to your 'home theatre' system.
The one we have delivers the best when S-video is used but that requires a separate path for sound.
The standard colors for audio in and outputs are red(=right) and white(= left) and often cables are supplied with the same color coding.
The usual connections will be named 'Line in' and 'Line out.' The outputs deliver specified voltage into a specified load (or termination) and the inputs expect that condition.
This ensures that volume controls act in a sensible manner.
Sep 05, 2008 | Zenith XBS444 System
Zenith XBS444 shuts off
I just posted the fix for this problem under the post of davidlentz who is having the same problem. Problem is IC706 located on the audio output board Part number is KIA7805A.
Jan 23, 2008 | Zenith XBS444 System
Audio problem
signs of a defective Filter Capacitor. I suggest you replace all capacitors in the Power supply and try.
Sep 19, 2006 | Zenith XBS444 System
Progressive Scan
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
works with remote only
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
Jan 21, 2006 | Zenith XBS444 System
Zenith XBS444 System Logo
425 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
