Question about World Office Products Papermate PM-600C Shredder
Paper shredder not working
The shredder is making a loud noise when its in Rev its not shredding. Its taking the paper but it isn't going through. I've only used the shredder once to shred some paper, and I followed directions. When I put the shredder on Auto it makes a loud noise for a minute then stops
  • 32 Answers
Sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Posted on Sep 01, 2009
  • 1959 Answers
SOURCE: Shredder will not start when paper is inserted.
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Posted on Nov 13, 2009
Testimonial: "This confirms my fears. The motor is fried. "
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
  • 102 Answers
SOURCE: Techko SH2106PA
your blades have either become dull or have spread due to a jam or a broken mount on cutter if your in warranty contact manufacturer if not time to buy a new machine.
Posted on Mar 02, 2008
  • 1185 Answers
SOURCE: the shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Posted on Jun 12, 2009
  • 610 Answers
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
There is a high, loud buzzing noise when you feed more than one sheet into the shredder. The paper doesn't feed and the shredder needs to be unplugged to stop the noise. Do I need a new one?
With power removed, inspect the shredding mechanism and remove all residue. If you shredded coated paper or plastic in the past, you may have to scrape out the remains.
Oct 06, 2015 | Shredder Office Equipment & Supplies
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
Yesterday when i was using it it started to make a really loud noise. reverse makes the normal noise but on auto it sounds bad. i cleaned out the inside but there is still paper stuck that i cant pull out....
It will not hurt to pour some lightweight shredder oil onto the cutting shafts....depending on how much you use the machine this should almost be part of a regular operation... I normally suggest to customers to pour the shredder oil onto a sheet of paper in an "S" pattern and then shred the sheet of paper....also shredders will work more reliably if you only shred about 70% of the rated capacity...less strain on the motor and parts and this results in fewer jams and longer machine life.
Oct 08, 2010 | Royal VF1012mx Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here:
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
Shredders on but is not working?!
you need to make sure that the paper detection sensor is not stuck or full of paper dust.....
May 18, 2009 | Fellowes 3011001 Shredder
REALLY loud grinding noise
If it doesn't work at all, there is a reset button for the unit. After it is reset keep the cutters lubed.
Jul 16, 2017 | Royal CIA 12X Shredder
Won't pull paper
I have the same shredder with a different problem. Maybe we can help each other.
It sounds like you have paper jammed in the shredding mechanism. I've cleaned paper jams out of mine quite a few times. The first and most important step is to make sure the shredder is unplugged. Hold the unit up to look through the shredding slot. Some of the openings between the opposing shredding wheels will be filled with paper. Using a small screwdriver (narrow blade at least 3 inches long) you can gently push the paper through. It works best if you can us a pair of needle-nosed plyers to pull the paper out the other side. It takes patience, but it works. Good Luck.
My problem is that after I opened mine up, I turned it over to shake out shreds of paper. When I did this, the entire works fell out of the case and all of the wires disconnected from the 3-way switch. Can you look in yours and describe how the wires are connected to the 8 contacts on the switch. (a digital photograph would be GREAT!
I hope we can help each other.
-- Wcbyers
Jul 13, 2008 | Tech Solution TS-2550 Shredder
World Office Products Papermate PM-600C Shredder Logo
491 people viewed this question
Top World Office Products Office Equipment & Supplies Experts
Are you a World Office Products Office Equipment and Supply Expert? Answer questions, earn points and help others
