Question about Sony KP-57WS500 57" Rear Projection Television
5 yr sony/ stanby light
Model kp57ws520
The light is blinking 9 times ,then recycled.
Talked to sony,reset the power.
No results..Am hpoing to resolve this w/o sony cost.
I think its the projection bulb?
  • 29 Answers
THERE ARE NUMEROUS COMPONENTS WHICH MAY CAUSE YOUR PROBLEM. EXPECT $300 - $400 REPAIR BILL
TAKE SET TO SONY AUTHORIZED SERVICER.
30 YR SERVICER
APGONZO
Posted on Jan 12, 2009
10 blinks Sony rear projection
If your model is a KP57WS520 and the light blinks 10 times thats a fairly common issue and there is a repair kit for that error at the following link it bottom of the page http://tvrepairworld.com/rear_projection_tv_circuit_boards/rca_circuit_boards
Apr 03, 2013 | Panasonic PT-53WX53 53" Rear Projection...
I have a sony 52" rear projection tv red light
I will need the model number to assist if its the KP51WS520 the 9 blinks is zero cross diodes on the g board.
Aug 02, 2011 | Sony Televison & Video
Sony Trinitron stayby light blinks 9 times. Unit
Theirs a problem in CRT board,the inner part of your TV,at the power supply section.Try to check fuse at power supply section.there are 2 fuse in the board.The AC fuse and the DC fuse check the DC fuse.
Jul 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stanby light blinks 9 times after powering on but no picture
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections.
Hope that helps.
Jan 17, 2011 | Sony KDL-46XBR2 Television
Sony 9 blink problem
9 blinks shows problem in power supply (G Board) and service manual suggest to check D6116 or D6301 that could be open on G Board.
Thanks.
Sep 01, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Jul 19, 2009 | Sony KP-57WV600 57" Rear Projection...
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Kp57ws520
This is called a zero cross detect problem and has to do with the power supply. There are one or two bad switching diodes in the power supply
Oct 17, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony Bravia KDL-40S2000 40 inch
We have the same problem.. Checked the Sony site after a few clicks got to: http://www.iq.sony.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=966,E=0000000000761838071,K=1708,Sxi=1,Case=obj(460991),VARSET_OBJ=460991,VARSET_TSRC=results,UseTemplate=case.tem,VARSET_TOP=TRUE
We followed the 'simple' troubleshooting tips then called the service center. As mentioned above 4 blinks indicates a bad panel. The repairman that visited said that he is ordering a new power supply (much cheaper than the back panel) for their first try. I will post again when my set is back on.
Jan 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
182 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
