Question about Honeywell HS400 Stand (Pedestal) Fan
Honeywell Fan Fan will only run momentarily, then shuts off. Any help with problem would be appreciated. Thanks Marvin
The same thing happens to mine..however i've noticed that it only shuts off while oscillating. try keeping it stationery
Posted on Oct 02, 2008
  • 883 Answers
To rule out an overheat condition, if you immediately try again, does the exact sequence repeat, and again many times without change in "only run momentarily" time? if the time "only run momentarily" never changes, then overheat is not the problem. so look for a faulty timer function that repeatedly times out. try changing timer settings.
Posted on May 31, 2007
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
I have a Marvin 1210 window fan with a rotating front grill. The grill has come unscrewed from the fan motor shaft and I can not see how to take the front nose cone apart to get to the screw so I can...
mcdevito75 here, hello ken, I did a fast search and I think www. can help you out with Marvin air fans, I didn"t find anything on Marvin Air Fans itself. Now about the nose cone covering the nut holding the blade to the fan shaft, most of these nose covers are press fit, see if you can gently pry that nose cover off with a small screwdriver.
Jul 23, 2010 | Marvin 1210 Floor / Box Fan
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Jul 03, 2008 | Marvin 1210 Floor / Box Fan
Heater Shuts off at 1500 Watts
Could be a bad element if the heater does not run at all at 1500w.
If it runs a little before stopping, things could just be dirty causing the thermal sensor to shut it off. A good cleaning is needed in that case.
Good Luck,
Oct 09, 2007 | Marvin W.B. 3150 Convector Heater/Fan
Honeywell HS400 Stand (Pedestal) Fan Logo
219 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
