Question about Dirt Devil M087700SV Bagless Upright Vacuum
Hoover Self Propelled Upright
Self Propelled reverse works smoothly but forward requires a bit of a "push" to keep it moving or it will go verrry slowly. What's the fix, please!! Carpet is short nap and beater bar seems to be operating smoothly.
5 Suggested Answers
SOURCE: e drive problem. Self propelled feature drives in reverse, but not in forward.
I took the wires loose from the drive circuit card. Using the ohm meter to check for a broken wire, all three checked out fine. I then rigged up a set of jumpers that allowed me to jump across the terminals on the circuit board from the common to the two neutrals. Sure enough the drive motor works perfectly both forward & reverse. The magnetically sensetive transister type switch was the culprit. I have replaced the switch & it works great. I wish I could identify the transistor & only buy it & solder it in.
Posted on Jun 25, 2007
  • 7 Answers
SOURCE: not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Posted on Dec 17, 2008
SOURCE: Dirt Devil Featherlite - how to remove the beater bar to clean
If you lay it down and look under the base- by the brush roll- there are three screws you have to remove w/ a philips head screwdriver to get the base plate off. From there you can take out the brush roll, etc.
Posted on Mar 15, 2009
  • 281 Answers
SOURCE: just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Posted on May 05, 2009
SOURCE: I bought the 085845 yesterday, put it together and
I called Dirt Devil and they said return it!
Posted on Feb 01, 2010
0 characters
1 Points
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Can't get bottom plate off hoover model
Am a bit confused because I can't find the model number you give on the Hoover website, so am not sure exactly which machine we're dealing with. However, the procedure for removing the bottom plate is common to most self-propelled upright wind-tunnel models, and it's simply a matter of laying the machine flat, turning it over and removing the four recessed screws that hold it in place. It can then just be lifted off. If this doesn't work for you, perhaps you could confirm the model number and I'll try again. It will also help if you say what country you're in. Good luck!
Feb 26, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Self-propelled Broken?
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Aug 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
How do you replace the forward / reverse cable? How do you replace the forward / reverse cable?
Posted by HANDYBILL on Jun 10, 2008
I don't know how the end fits back on the replacement cable.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. There is a hook on the bottom of the vacuum and @ the top by the handle as well. You may what to get a schematic or owner’s manual to see how they hook up because of the newer and different Model #’s for Hoover. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover self-propelled u6630-900 reverse not working
THe forward/reverse lever (made of plastic) possibly is broken. New part is about $10.00
Dec 12, 2007 | Hoover U6630-900 WindTunnel Bagless...
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Dirt Devil M087700SV Bagless Upright Vacuum Logo
20 people viewed this question
Top Dirt Devil Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
