Question about Panasonic SVAV100 D-Snap MPEG4 Digital Video Recorder Camcorder
Panasonic dv camcorder wont record
My PV-GS14 camcorder is stuck in pause, will not record, has blue bars which I think is clogged head (wont take cleaning tape), has eject problems, the eject problem, have to hit reset constantly, I'm sure is an unrelated problem from the others. Is there a fix to make it record?
Heard that if you record on a new tape all the way through, it will clean the heads, & rid of the blue bars.
    Dedicated:
    Visited the website for 20 consecutive days.
  • Panasonic Expert
  • 434 Answers
Clean the head with cotton swab
Posted on Sep 10, 2017
SOURCE:
  • 883 Answers
SOURCE: removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Posted on Jun 06, 2007
SOURCE: where is the reset button
I haven't used mine for over 2 years because of the mildew detected warning and not being able to find anyone to fix it for me. I just found this on the internet and am going to try it when my battery charges. Seems this is a common error for these palmcorders... good luck! "When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew."
Posted on Oct 08, 2007
SOURCE: Canon zr300 ejects tapes
The solution for this required sending it to Canon factory service. I was very reluctant to do this because I've heard horror stories about Canon service, but I was actually pleasantly surprised. The total cost was only about $65 and the shipping and service turn around time was amazingly fast. I was expecting weeks to go by. If memory serves me right I shipped it and received it back in less than 2 weeks.
This is a known problem with Canon and would be covered under warranty if your time hasn't run out.
Posted on Sep 25, 2008
SOURCE: Cannon MD101 Wont eject Tape /No Power
same problem :(
Posted on Oct 05, 2008
  • 151 Answers
SOURCE: Blue bars during playback
Your heads are dirty , clean with a cleaning tape.
Posted on May 12, 2009
When trying to play a tape the tape shows lines through it. Anyone know how to fix this?
You may need a MiniDV head cleaner tape. Read the instructions on the tape carefully and good luck.
Sep 25, 2009 | Panasonic Palmcorder PV-GS14 Mini DV...
Panasonic PV-DV103 Playback Problem
check ur recording mode it may be on snapshotmode change it. or clean ur cam head
Jun 04, 2009 | Panasonic PV-DV103 Mini DV Digital...
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
May 09, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
I have a Panasonic PV-GS14 and it ALWAYS says 'Push Reset Button'
I had the same problem. In desperation, I picked up my trusty can of compressed air and aimed a few shots into the recorder/playback mechanism. Worked like charm.
Feb 18, 2009 | Panasonic Palmcorder PV-GS14 Mini DV...
Turn the sound off for recording on PV-GS320 DV camcorder
Hi, I think the PVGS320 has an external mic input. Plug in a 3.5 mini dummy jack and that should turn off it internal microphone.
Nov 15, 2008 | Panasonic PV-GS320 Camcorder
Blue Bars and No Sound
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Dec 20, 2007 | Panasonic PV-GS39 Mini DV Digital...
Blue bars across video
I have the same problem with my PV-GS14. You have to find the last spot you recorded in, pause it, then switch to record, and just record something for a couple of seconds. Switch back to playback, and it should be fine. Neonlaundry, I read your other posts, and it seems we both have the same problems. If you find a solution, please post it. Thnks.
Mar 13, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
My camcorder not playing back
First, try head cleaning by trained technician. Tech will clean manually with cleaning chemical each head to make sure video heads are performing 100%. Otherwise, they will probably quotes you for tracking adjustment. Head cleaning is typically around $25-50. Tracking adjustment might cost you around $100-200 in US depending on service time.
Mar 17, 2007 | Panasonic Palmcorder PV-GS14 Mini DV...
Tape Jam
Can anyone give any information on this problem? I am having the same problem, on Christmas of all days. Any help would be much appreciated. Thanks
Nov 23, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Open Questions:
See all Panasonic SVAV100 D-Snap MPEG4 Digital Video Questions
Panasonic SVAV100 D-Snap MPEG4 Digital Video Recorder Camcorder Logo
137 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
