Question about Sony RDR-HX715 DVD Recorder
Sony RDR-HX715 displays "recovery" then "welcome"
Recorder displays "recovery" and then "welcome" over and over.
Unplugging did not help.Holding power button down did not help.Holding down HDD button did not help.Leaving recorder on did not help.
  • ldishman1998 Mar 20, 2009
    Disconnecting internal cables did not help.
  • Sony Master
  • 19,396 Answers
The only two resets available are the hard reset (unplugging) and then holding power button or play while you hook back power at the same time,
try this last, if it does not work, then the unit must be taken apart.
Posted on Jan 07, 2009
  • Sony Master
  • 4,806 Answers
Hi there
It sounds like there was a failed recording due to power failure or being turned off, thats why recovery appears on display.
Hold in the on/off button for about 30 seconds and the welcome message should reappear. If its still the same unplug the machine from the mains for a while to see if it resets.
If that doesen't work you will have to have the machine looked at
Good luck
  • 492 Answers
The diagnostics can be executed using the remote commander (Remote Control Mode 3) and monitor.
To execute the service mode, connect the VIDEO OUT (L2 OUT) connector to the monitor.
Connect the AC power cord to the power outlet.
A message, "WELCOME" appears on the display panel of the main unit.
Keep holding down the "REC PAUSE", "REC STOP" and "REC" keys, of the main unit (about 10 seconds) until the screen appears on the monitor display.
Either "OK" or "NG" appears on the monitor screen while the diagnostics is in progress.
You can judge the respective device or its peripheral from the message of either "OK" or "NG" on the monitor screen.
When an abnormality is detected, the diagnostics is stopped at that moment and you can select to proceed the diagnostics or to stop it.
Use the keys on the front panel of the main unit to operate the diagnostics.
If the keys mentioned don't exist, use the keys that provide the equivalent funtion.  Remember, these are the instructions for what is probably the US equivalent for the RDRHX710.
Please let us know how you make out
    Genius:
  • 1,847 Answers
This happen when you play from the hdd or dvd or at all time?
    Sergeant:
    Novelist:
  • 326 Answers
Remove the internal cable connections and reinsert them properly
SONY RDR-HX950 is showing WELCOME in display at startup, nothing else happends
i have a sony HXD-1065 which was doing exactly the same thing.
i searched loads of forums to get some idea of the cause but nothing.
to cut a long story short, i put the recorder away in a cupboard for approx 4 months then just as i was about to list it on ebay as faulty i thought i'd just switch it on and see what happens and it came on and loaded up as it should with no problem so i unplugged it and plugged it back in several times to see if the permanent welcome message came back but it just loaded and has worked perfect for the last 5 or 6 months.
i found out later that the memory capacitor needs to fully discharge before it can reset itself on power-up.
i'm not sure exactly how long this takes but it took me 4 months to find it works again.
Jun 30, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony rdr-hxd860 powers on gets to 'welcome' on display and stays there. no dvd light, no hdd light. nothing displayed on tv
Hi, mine has exactly the same problem, it only started to do it after the recent upgrade, coincidence ?? I was just wondering if you had been able to come up with any solutions. Many thanks
Jan 18, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
My DVD Recorder Won't Start
Sometimes, the Sony documentation recommends unplugging the DVD Recorder for at least 30 minutes, instead of the regular 15 seconds. I know this timing makes a difference on DVR's.
Jun 25, 2009 | Sony RDR-GX300 DVD Recorder
Sony RDR-GX220 DVD Recorder is not going past WELCOME
This is not a solution but was told by repairers that an ic has gone bad.
I resolved the problem for a while when I removed internal cable and some how got it working.It worked as long as it was powered up. Had a power failure and now battle to resolve the problem. Suspect that it can be a low voltage out of the regulator ic. The mystery was that when I got it working it worked perfectly. The firmware is also doing a power test and I think this is failing and thats why it is display welcome.
Feb 27, 2009 | Sony RDR-GX220 DVD Recorder
My sony hd dvd recorder RDR-HXD 760 wont turn on or off, it just sits half way and says welcome, have tried holding on/off button down which does work for a bit the it comes back on by itself and goes back...
I had the same problem, my recorder was past it's warranty though. So I opened the case (4 screws on sides & 3 [silver] screws on rear) then unsecured the HDD (4 screws with rubber grommets and 1 screw with thin metal flange) I then disconnected the data and power cable (as illustrated on HDD) powered the whole unit up and got nothing (obviously) reconnected the HDD and plugged the unit in. It powered up and then turned itself off. I then turned it on using the power button and voila, it worked perfectly! All HDD stored videos were still there too! The unit even held the same time.
May 22, 2008 | Televison & Video
Hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Televison & Video Logo
316 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
