Question about Harman Kardon AVR 225 Receiver
Humming noise I have a humming noise when I play the tv or the dvd coming from my receiver or the speakers. When I play the radio it does not hum. I have surround sound and a Harmon Kardon AVR-35.
  • 492 Answers
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Posted on Jan 07, 2009
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
I have a Denon Surround receiver, model AVR-1804 which manages our home surround sound system (6 speakers including a sub-woofer). When the TV (Visio HDTV) is turned off, but the receiver is still on, we...
Some kind of ground potential difference between the TV and the AVR or perhaps it's a badly shielded cable.
Considering the multitude of variations you may have connecting the TV video and audio to the receiver it's hard to pin it down, but try removing all cabling between them and that should silence the hum. Add any cable and see if it comes back. Disconnect it. Test each cable the same way. At some point a single cable might be implicated. Replace it.
Also consider routing of any analog audio cable near power cables, the TV or other sources of high voltage and magnetic fields. I have a known problem when my overhead dimmer-controlled track lighting is on. Food for thought.
Feb 19, 2011 | Denon AVR-1804 Receiver
How do I stop the hum coming from my surround sound speakers
You have a ground loop, most probably. Try grounding your receiver by running a copper wire to the screw on the electrical outlet.
May 02, 2010 | Technics SA-AX540 Receiver
Surround sound is fine when playing dvd but when switched to tv a humming noise is heard
Sounds like a Ground loop, your TV plugged is plugged into a different outlet than your stereo is.
Nov 02, 2009 | Sony Audio Players & Recorders
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
Humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Sep 13, 2009 | Yamaha HTR-6030 Receiver
Humming noise when Dvd plays
the motor that's spinning the dvd is bad. sorry you have to buy a new one if you don't want to hear the noise. hope this help
Dec 17, 2008 | Coby DVD-937 5.1 Channel DVD...
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Oct 02, 2008 | Yamaha HTR-5440 Receiver
Hum & noise coming from the speakers
IF it was too load you probable blew the speaker Just disconnect the side that is making noise or is it both side?
Oct 16, 2007 | Coby DVD-937 5.1 Channel DVD...
Loud Humming
It's possible a fan or a hard drive is going bad. When the bearings in those devices start to go out they a start making noises like that.
Jul 18, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Harman Kardon AVR 225 Receiver Logo
1,037 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
