Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Piston ring install up or down Poulan 2150 16"
Piston ring is has chamfered ends that look like a v when you look at it from the side. Does this v go right side up or like an upside down like ^
There is a pin in the groove where the ends of the ring meets but does it matter which way ring is installed.(with v up or down)
  • Tony White
    Tony White Jan 07, 2009
    Thanks very much. makes sense. sometimes a person second guesses himself. I appreciate your quick response.
  • Anonymous Mar 29, 2014
    I am installing a new piston in a new cylinder
  • 181 Answers
The groves go into the pins.v is up to fit into those pins.the pins go to the intake side of piston
Posted on Jan 07, 2009
Poulan chainsaw will kick back when trying to start it. It has a new cylinder and piston kit just put in it.
Sounds like the timing is too far advanced.
I'd be pulling the flywheel and retard the spark about 2 degrees.
Jan 18, 2016 | Poulan Garden
How to replace the piston and rod assembly
Many small hobby machines have a chamfer at the cylinder base to act as a leed into the cylinder, just make sure the piston rings are located properly, there will be a small peg in the piston to stop the rings rotating, the open ends of the ring should be cenral to this pis so as the ring compressis, if there is no leed in the cylinder you will need to use a ring compressor, these can be purchased in kits are are fairly inexpensive, make sure you oil both piston and bore before assembly.
May 02, 2012 | Craftsman Gas Mini - Tiller/Edger
The engine has blown. I need to replace it or change pistons and rings. How difficult is it to change pistons and rings?
It can be time consuming and the end result may not be desirable if you haven't done it before.
--- The following is just a sample of what to do once the engine is torn down: Pistons and Connecting Rods
  1. Before installing the piston/connecting rod assembly, oil the pistons, piston rings and the cylinder walls with light engine oil. Install connecting rod bolt protectors or rubber hose onto the connecting rod bolts/studs. Also perform the following:
    1. Select the proper ring set for the size cylinder bore.
    2. Position the ring in the bore in which it is going to be used.
    3. Push the ring down into the bore area where normal ring wear is not encountered.
    4. Use the head of the piston to position the ring in the bore so that the ring is square with the cylinder wall. Use caution to avoid damage to the ring or cylinder bore.
    5. Measure the gap between the ends of the ring with a feeler gauge. Ring gap in a worn cylinder is normally greater than specification. If the ring gap is greater than the specified limits, try an oversize ring set. Fig. 5: Checking the piston ring-to-ring groove side clearance using the ring and a feeler gauge tccs3923.gif
    6. Check the ring side clearance of the compression rings with a feeler gauge inserted between the ring and its lower land according to specification. The gauge should slide freely around the entire ring circumference without binding. Any wear that occurs will form a step at the inner portion of the lower land. If the lower lands have high steps, the piston should be replaced. Fig. 6: The notch on the side of the bearing cap matches the tang on the bearing insert tccs3917.gif
  2. Unless new pistons are installed, be sure to install the pistons in the cylinders from which they were removed. The numbers on the connecting rod and bearing cap must be on the same side when installed in the cylinder bore. If a connecting rod is ever transposed from one engine or cylinder to another, new bearings should be fitted and the connecting rod should be numbered to correspond with the new cylinder number. The notch on the piston head goes toward the front of the engine.
  3. Install all of the rod bearing inserts into the rods and caps. Fig. 7: Most rings are marked to show which side of the ring should face up when installed to the piston tccs3222.gif
  4. Install the rings to the pistons. Install the oil control ring first, then the second compression ring and finally the top compression ring. Use a piston ring expander tool to aid in installation and to help reduce the chance of breakage. Fig. 8: Install the piston and rod assembly into the block using a ring compressor and the handle of a hammer tccs3914.gif
  5. Make sure the ring gaps are properly spaced around the circumference of the piston. Fit a piston ring compressor around the piston and slide the piston and connecting rod assembly down into the cylinder bore, pushing it in with the wooden hammer handle. Push the piston down until it is only slightly below the top of the cylinder bore. Guide the connecting rod onto the crankshaft bearing journal carefully, to avoid damaging the crankshaft.
  6. Check the bearing clearance of all the rod bearings, fitting them to the crankshaft bearing journals. Follow the procedure in the crankshaft installation above.
  7. After the bearings have been fitted, apply a light coating of assembly oil to the journals and bearings.
  8. Turn the crankshaft until the appropriate bearing journal is at the bottom of its stroke, then push the piston assembly all the way down until the connecting rod bearing seats on the crankshaft journal. Be careful not to allow the bearing cap screws to strike the crankshaft bearing journals and damage them.
  9. After the piston and connecting rod assemblies have been installed, check the connecting rod side clearance on each crankshaft journal.
  10. Prime and install the oil pump and the oil pump intake tube.
  11. Install the auxiliary/balance shaft(s)/assembly(ies).
OHV Engines CAMSHAFT, LIFTERS AND TIMING ASSEMBLY
  1. Install the camshaft.
  2. Install the lifters/followers into their bores.
  3. Install the timing gears/chain assembly.
CYLINDER HEAD(S)
  1. Install the cylinder head(s) using new gaskets.
  2. Assemble the rest of the valve train (pushrods and rocker arms and/or shafts).
OHC Engines CYLINDER HEAD(S)
  2. Install the timing sprockets/gears and the belt/chain assemblies.
Engine Covers and Components Install the timing cover(s) and oil pan. Refer to your notes and drawings made prior to disassembly and install all of the components that were removed. Install the engine into the vehicle. Engine Start-up and Break-in STARTING THE ENGINE Now that the engine is installed and every wire and hose is properly connected, go back and double check that all coolant and vacuum hoses are connected. Check that your oil drain plug is installed and properly tightened. If not already done, install a new oil filter onto the engine. Fill the crankcase with the proper amount and grade of engine oil. Fill the cooling system with a 50/50 mixture of coolant/water.
  1. Connect the vehicle battery.
  2. Start the engine. Keep your eye on your oil pressure indicator; if it does not indicate oil pressure within 10 seconds of starting, turn the vehicle OFF. WARNING
    Damage to the engine can result if it is allowed to run with no oil pressure. Check the engine oil level to make sure that it is full. Check for any leaks and if found, repair the leaks before continuing. If there is still no indication of oil pressure, you may need to prime the system.
  3. Confirm that there are no fluid leaks (oil or other).
  4. Allow the engine to reach normal operating temperature (the upper radiator hose will be hot to the touch).
  5. At this point any necessary checks or adjustments can be performed, such as ignition timing.
  6. Install any remaining components or body panels which were removed. prev.gif next.gif
Oct 17, 2010 | 1995 Ford Thunderbird
How do I install the compression ring into the cylinder of a sears model # 919165140?
Similar to an automotive seal, if it has a beveled edge it should down. Place the ring on the piston groove (don't worry), it should look like the ring is side by side with the piston. With that in place, roll the ring along the groove, making sure the opened end flings on top of the piston. While rolling the ring along the groove, it should end up screwing it's self into position on the piston groove. Start from the bottom grove if it has multiple scrapers.
Other way is buy a ring spreader tool and a compression tool from any auto parts store. This will come with instructions and you'll get the hang of it in no time.
Jul 23, 2010 | Craftsman Air Tools & Compressors
How do i remove piston pin from 375 poulan pro
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I suggest you look around the above site. Someone here has been where you are. You can join for free and they are a very helpful group of folk.
Apr 21, 2010 | Poulan Pro Chain Saw 46cc 20"
How do I get to the piston rings on a 1981 honda xl 500 off
the cylinder will slide off the top of the piston, then you can replace the rings and slide the cylinder back down over the top of the piston. The bottom edge of the cylinder sleeve should have a small chamfer in it to aid in getting the rings into the cylinder.
Mar 12, 2010 | 1981 Honda CX 500 A
I'm unable to start the engine.It won't even kick over.
Most likely you have low compression caused by stuck piston ring or a scored piston and cylinder. This unit was made by Poulan and
they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the
new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Your cylinder could also just be worn out. This blower has a fairly short engine life.
Sep 21, 2009 | Poulan Featherlite Gas Blower, with Low...
Poulan leaf blower bv1850 Runs greate for about 30 seconds, then dies. Replaced fuel lines and installed carb kit. No better. Adjusted the one adjustment screw out 1-1/2 turns out for starting position....
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
Sep 20, 2009 | Garden
Poulan/Weed Eater No. Bvm200le kills when taking it off choke or giving it gas.
You might also need to rebuild the carb.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Engine pulls over good, without spark plug in , but very hard to
nope the rod will not stretch.did you put the piston on backwards.ring openings go to the intake side of piston
Jan 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
907 people viewed this question
Top Poulan Garden Experts
Dwain Pippen
Roland W VanLue
Roland W VanLue
EugenesDIYDen
EugenesDIYDen
Are you a Poulan Garden Expert? Answer questions, earn points and help others
