Question about RCA HD61LPW164 61" Rear Projection HDTV
RCA projection television INPUT problem
I have had my television for about a month and everything has worked fine. Yesterday I switched the channel over to VID2 which is where it has always been for the DVD player, but instead of my DVD I get whatever channel I was on with the audio of the DVD player. Also if I change to VID1 or Front the televsion picture is on instead of a blank screen. Any idea what might have caused this, and is there a way to fix it without new parts? Any information would be very much appreciated. Thank You! -Jeremy Hester
techman
  • 3130 Answers
SOURCE: Integrated DVD player
If your handy, then try to disassemble the DVD .player from the unit and manualy clean the lens assy,but please be aware of the HI Voltage dangers inside of a tV set. if your not then Please call a pro top assist you with this repair. If the units not worth fixing then simply buy and inexpensive DVD player/recorder and hook it up via the external inputs. Good Luck
Posted on Jul 24, 2006
  • 308 Answers
SOURCE: RCA D52W15 52 in. Rear Projection HDTV-Ready Television
The component connections are usually video only and the audio goes to separate connectors set aside for that input. Check your manual to make sure you have all the connections made.
Posted on Dec 31, 2007
ctf1800
  • 4402 Answers
SOURCE: RCA P52820BL Projection TV - Video intermittently works???
bad ground on tuner or bad tuner
Posted on Jan 09, 2008
ladywinn
  • 5138 Answers
SOURCE: rca d52w19 power but no picture...
Solder around flyback pinns this should fix it.
Posted on Feb 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Posted on Apr 13, 2008
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
How do you switch on input with no remote control?
Channel down past channel 3..... however if the tv moves back to 99 or back around to 3, you must have a remote because this is the way the manufacturer made the tv.
May 05, 2010 | RCA P52926 52" Rear Projection Television
TV Changes Channels on its own
On the front panel board power/ch-/ch+ vol-/vol+ replace contact switches replace all of them.For some odd reasons these contact switches just keep going out they had alot of them bad.
Feb 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Starts running thru channels and inputs
The Micro switches are leaky. They are soldered on the control panel in the front. Either replace the panel or the switchs. You can test this by unsoldering all the switchs and leaving the IR Sensor. You can control the set by using the remote remote . If this help let me know.
Oct 14, 2008 | RCA P61960 61" Rear Projection Television
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips hdtv
to switch that you need rca 3 color red, blue, green to view
more that 480i , or HDMI conection
Jan 20, 2008 | Philips 55PW9363 55" Rear Projection...
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
RCA HD61LPW164 61" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
