Question about Gateway MX3560 Notebook
Motherboard Repalcement I have a laptop - Details of the laptop: Gateway MX3560(model) serial # N625AC1052628 ( on the back of the laptop) Motherboard part number # 103501(required item) The motherboard of this got damaged and is not available.So, i wanna know, can i replace it with any other motheboard type - if there is any other motherboard which is compatible with this type.IF yes, please inform me as i am really worried about it. Other details are as follows - Processor Intel® Centrino? Mobile Technology with Intel® Pentium® M Processor 735 (2 MB L2 Cache | 1.70 GHz | 400 MHz FSB) Chipset Intel® 855GM Screen 14-inch Widescreen Ultrabright WXGA TFT Memory 512 MB DDR (1 × 512 MB) SODIMM (PC2700) Expandable to 1.5 GB Video Intel® Extreme 2 Graphics 32 MB Shared Video Memory Audio AC '97 2.3 Compliant Audio Built-in Stereo Speakers Hard Drive 80 GB HDD (4200 RPM) Optical Drive DVD +/- RW Multi-Format Double Layer Write maximum: 8X DVD +/-R, 4X DVD +/- RW, 2.4X DVD+R DL, 24X CD-R and 10X CD-RW disks Reads maximum: 8X DVD-ROM, 8X DL/+RW, 24X CD-ROM disks Media Reader 4-in-1 Digital Media Manager Secure Digital, Memory Stick, Memory Stick-Pro, and MMC Modem 56K ITU V.90 Fax/Modem Network Intel® PRO/Wireless LAN 802.11g SecureEasySetup? 10/100Mbps built-in Ethernet Pointing Device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces 3 - USB 2.0 Ports 1 - IEEE 1394 port 1 - VGA External Connector 1 - RJ11 1 - RJ45 Microphone In Headphone / Audio Out Battery 6-cell Lithium-ion Dimensions 1.24-inches H × 13-inches W × 9.7-inches D Weight 5.24 pounds
  • 51 Answers
SOURCE: Motherboard Replacement
I would check Ebay you may be able to find a replacement one for cheap.
Posted on Jan 10, 2009
Will windows 7 work on the gateway mx3560
Click on the following link:
http://www.microsoft.com/en-us/download/details.aspx?id=20
Download this app from Microsoft and run the App to see if your computer is compatible.
Jan 29, 2013 | Gateway Computers & Internet
I forgot my password to log on to my gateway laptop model # mx3560
Try loading computer in safe mode. You can do this by repeatedly pressing F8 upon start up it will take you to an advanced options menu. Within there select safe mode by using arrows to navigate up and down. Then press enter when safe mode is highlighted. When it loads it will look alot different DONT FREAK OUT! :) Then there will be a couple of user accounts u can try logging into them and leaving the password field blank. Some times there are accounts w/o a password and will allow access into computer. From there you can create a new password within the control panel & user accounts
Nov 11, 2010 | Gateway MX3560 Notebook
Dark display on monitor
go to control panel and make sure screensaver and hibernate mode is off.
Jun 22, 2009 | Gateway MX3560 Notebook
Battery wont charge.
does it work fine without the battery and with just the ac adaptor?
Mar 27, 2009 | Gateway MX3560 Notebook
My batter wont charge.
first you need to check that is the light on the power cord on the adapter is coming if yes then it is supplying the current to teh machine and it is not charging the battery then mother board needs to be replaced if the light on the adapter is not coming up then need to chage the adapter .
Jan 07, 2009 | Gateway MX3560 Notebook
Gateway mx3560 wireless (yellow exclamation mark) on device manager
Obtain an ethernet cable and connect to the Gateway Support site using wired network temporarily to download and install the proper wireless driver.
May 29, 2008 | Gateway MX3560 Notebook
Gateway MX3560 Notebook Logo
199 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
